Old Dec 27, 2015, 08:58 PM
Mike_eee is online now
Find More Posts by Mike_eee
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
Help!
Suggest me a 90mm 8S EDF Jet!
Hello Guys,
Suggest me a good 8S edf 90mm capable Jet for the following powersystem I already have:
JETFAN 90 GRP 8s 3Kw COMBO
29.58v / 101A / 2990w / 4.5+kg thrust
LINK:http://www.extremerc.com.au/estore/i...oducts_id=1423
Would like something that I can drop this power set up and use my 8s 5000 mah revo packs....
I do like scale ..but sport jet would do,.. Please advise.
Mike_eee is online now Find More Posts by Mike_eee
Old Dec 27, 2015, 09:18 PM
supercollider is offline
Find More Posts by supercollider
C.E.R.N. field tester
supercollider's Avatar
United States, NE
Joined Sep 2012
Seb Art Mini Avanti S. Straitforward and easy to build. Plenty of battery space.
Link:
http://www.sebart.it/edf-jets.html
Build thread:
http://www.rcgroups.com/forums/showthread.php?t=2330708
EDIT:
Sorry, I realized this was in the foamy section after I posted. Stinger 90 gets my vote.
supercollider is offline Find More Posts by supercollider
Old Dec 27, 2015, 09:38 PM
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
will stinger 90 carry the weight of a 8S 5000 mah pack?? the pack weights around 1000 grams ..
if its a drop fit with no mods then it will be awesome..want something in air quick
Old Dec 27, 2015, 09:39 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Taft Viper Jet V3 be sure to reduce the exhaust diameter a bit. Great flying jet! Room for 6000 mah 8s. You'll want to use an inlet ring on the fan the JF unit is $10.00 You setup will have good top speed and excellent vertical. Let us know what you decide.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Dec 27, 2015, 09:50 PM
tdford is online now
Find More Posts by tdford
Comin' in HOT!
tdford's Avatar
United States, CO
Joined Dec 2012
Freewing F-15. Scale, designed to take 8s, great flyer.
tdford is online now Find More Posts by tdford
Old Dec 27, 2015, 10:01 PM
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
the question is will it take a 8S 5000 mah pack
that's 2 x 5000 mah pack... which is 1000 mah by itself
Old Dec 28, 2015, 12:18 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Taft Viper Jet!
viperviper is offline Find More Posts by viperviper
Old Dec 28, 2015, 02:53 AM
Tcoltpilot56 is offline
Find More Posts by Tcoltpilot56
Tail Spin Tim
United States, MI, Warren
Joined Apr 2009
F16
Originally Posted by Mike_eee View Post
Hello Guys,
I set mine up for 8s with twin 35c 4500's.
Tcoltpilot56 is offline Find More Posts by Tcoltpilot56
Old Dec 28, 2015, 05:04 AM
GroundBound1 is offline
Find More Posts by GroundBound1
Epoxy flyer extraordinaire
GroundBound1's Avatar
United Kingdom, England, Surrey
Joined Jan 2013
The Taft Cobra is another option. Not as refined as the Freewing offerings but faster, designed for 8S and can easily for 8S 5000.
GroundBound1 is offline Find More Posts by GroundBound1
Old Dec 28, 2015, 09:37 AM
Comin' in HOT!
tdford's Avatar
United States, CO
Joined Dec 2012
It was designed around 6s 5000, with the bay large enough to fit a 2s 5000. Usually one pack is smaller then two packs so a 8s 5000 should fit fine.
Old Dec 28, 2015, 02:25 PM
bandetlol is online now
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
My Taft Cobra runs on an 8s 5000. The PnP version is set up for 8s 5000.
HSD J10 8s version will run on it. So will the HSD Super Viper.
bandetlol is online now Find More Posts by bandetlol
Old Dec 29, 2015, 12:22 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
The Cobra can also take 10S with ease!!!
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Sold Brand new Taft Cobra 8s 90mm EDF jet (PNF) xzd Aircraft - Electric - Jets (FS/W) 0 Aug 15, 2015 06:12 PM
Sold New Deluxe Cobra 90mm EDF 8S Jet Includes 8S Lipo (PNF) Combo chebert Aircraft - Electric - Jets (FS/W) 0 Apr 04, 2015 07:23 PM
Wanted HobbyKing™ Diablo 90mm Jet 1250mm OR ViperJet Composite 90mm EDF Jet 1370mm x5heli Aircraft - Electric - Jets (FS/W) 0 Sep 04, 2014 03:20 PM
Discussion 90mm foam EDF jet kit suggestions... Phoenix426 Foamy EDFs 5 Jul 12, 2010 11:24 PM
Discussion 8s 90mm EDF Setup Suggestions awood12345 Power Systems 1 Jul 09, 2009 06:53 AM
