Old Jul 08, 2015, 07:25 AM
wayne from Fla is offline
Find More Posts by wayne from Fla
Joined Jun 2008
Rigging a 3 masted schooner
Hello all, I am getting to the rigging portion of this project. I have a continuous loop for the three main sails but am having a problem trying to come up with a viable rigging plan for the jibs. The first jib is hung on a bobstay and sheets around the foremast. The next is attached to a forestay and sheets around the bob stay. The third is banked on out at the end of the bowsprit and sheets around the forestay. How is this done in miniature? And how can it be controlled? I have a sailwinch with a basket that could be used to sheet in a loop which might take care of two jibs but how do you handle a third jib? Even though this model is 55" on deck, the boat has very little freeboard and I'm running out of space wanting to keep everything above water level. I do have a lower bilge recessed into the lead keel that I poured and it has a self bailing bilge pump and I plan to use Corrosion X on everything if any unexpected water gets too high.
I'm hoping some one in the group has rigged a multi jibbed boat before and can though out some suggestions.
Thanks to the group, you've all been helpful through out my last three models!
Wayne
wayne from Fla is offline Find More Posts by wayne from Fla
Old Jul 08, 2015, 07:28 AM
Joined Jun 2008
Ok. You're going to have to excuse my typos as I have big fingers and a little phone!
Old Jul 08, 2015, 08:36 AM
JerryTodd is offline
Find More Posts by JerryTodd
SCALE Sailor
JerryTodd's Avatar
United States, MD, Severna Park
Joined Apr 2008
The bobstay is under the bowsprit, so you probably mean fore-stay.
3 jibs on a schooner are normally forestays'l, jib, and flying or outer-jib.
Anyway, a set-up to handle over-lapping sails is shown in my thread Here.
It rambles on a bit after that, but you should get the idea.
JerryTodd is offline Find More Posts by JerryTodd
Old Jul 08, 2015, 08:14 PM
SloopProvidence is offline
Find More Posts by SloopProvidence
SloopProvidence's Avatar
United States, NV, Gardnerville
Joined Jul 2007
yeah, I'm planning to use Jerry's method on my 32" LWL Top'sl Sloop. It has 3 fore'sl and a flying jib, which is actually in the clear above everything else.
Jason
SloopProvidence is offline Find More Posts by SloopProvidence
Old Jul 09, 2015, 11:12 AM
Joined Jun 2008
Jason, that servo system is Brilliant!
I'm not able to get a good enough copy to read the info with the last three pictures. Is there any way to get a bigger or better definition copy of them?
Old Jul 09, 2015, 01:10 PM
Joined Jul 2007
I just right click on them and save the image to my computer. If you first left click on them you also get the photo gallery pop-up.
Notice that I said.... "planning to use", I've drawn mine up in Solidworks, with some changes, but have not built it yet. Probably use my friend's laser cutter to do the arms. I'm designing some horns and will be using the master servo arm reversed to run against the horns to give a longer throw as the arm gets farther off center. Basically not just a doubler on the rigging but also a doubler on the physical arm too.
Jason
Old Jul 09, 2015, 01:34 PM
Joined Jun 2008
So how do you make it so the outer two arms swing freely?
Old Jul 09, 2015, 01:36 PM
Joined Jun 2008
I did move them to my computer but by the time I try to get them big enough to see, they become distorted. Tried to email them to myself still no good. Oh well.
Old Jul 09, 2015, 02:01 PM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
Click on the image and it'll open in "gallery mode" you can then right click the image and "view image" or "save image." I'm sure you'll find them plenty large enough to read.
Old Jul 09, 2015, 10:02 PM
Joined Jun 2008
I only have an iphone and an iPad. No right click button. Thanks though for the lead on the three armed servo. I'll have to experiment with making free moving arms.
Wayne
Old Jul 10, 2015, 11:42 AM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
Comment from an observer. The semaphore servo arm concept has lots of potential. It allows the slack side of twin sheets to be completely slack the entire time, not just 'sort of' slack like the action you get from a single arm.
But the sliding servo with multiple drums will still have a slack loop issue, as the servo will move based on the line with the most tension. The others will be slack. Now, if you can say this condition will NEVER happen, then maybe I'm worrying about something for nothing. Otherwise, a tension device for each unique drum/line would be required.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Jul 10, 2015, 01:53 PM
Joined Jun 2008
so, any thoughts on how to set up the free floating arms? The only thing I can come up with is machining a new, longer top servo screw to accommodate the floating arms with bushings and a nut for the very top. any one have an easier way to do this?
Old Jul 10, 2015, 03:24 PM
SCALE Sailor
JerryTodd's Avatar
Joined Apr 2008
You saw how I did it?
Old Jul 11, 2015, 06:37 AM
Joined Jun 2008
I saw the drawing but can't see how to attach the free floating arms.
Old Jul 11, 2015, 07:19 AM
Joined Jun 2008
I looked through all of your pics that I can find and don't see any of how you attach the free floating arms. Jerry, please help!
Discussion masts and rigging suppliers marko69 Scale Sailboats 12 Mar 20, 2015 08:03 AM
Discussion Three masted schooner TomHugill Scale Sailboats 9 Dec 03, 2013 08:05 PM
Discussion Greats Lakes 3-masted schooner Lucia Simpson - HAMMS Plans patmat2350 Scale Boats 1 Nov 09, 2012 05:52 PM
Discussion 3-Masted schooner Wm. Bisbee -- HAMMS Plans patmat2350 Scale Boats 0 Nov 09, 2012 11:47 AM
Build Log Two Masted Schooner (Rendition of the Bluenose) Cryodacry Sailboats 67 Aug 24, 2007 03:22 AM
