Old Jun 28, 2015, 12:55 PM
James Rhodes is offline
Find More Posts by James Rhodes
Joined Jun 2015
F-18 Scale 3D prints
Do anyone no where I can get a set.? I would like to attempt to make an EDF 1/10th scale version of the "C" model.
James Rhodes is offline Find More Posts by James Rhodes
Old Jun 28, 2015, 04:40 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
What exactly are you looking for? There's a reasonably accurate surface model on GrabCad.
https://grabcad.com/library/f-18-full-scale
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Jun 30, 2015, 09:08 AM
kcolraw is offline
Find More Posts by kcolraw
Traxxas.... !!!CONFORM!!!
United States, NC, Asheville
Joined Feb 2015
Good luck, I have been trying to find scale version's of the E/F super hornet with formers, but no luck.
kcolraw is offline Find More Posts by kcolraw
Old Jun 30, 2015, 11:03 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
He's been a busy boy-- found a decent answer here. http://www.rcgroups.com/forums/showp...02&postcount=1.... post #7
Can't say for sure if it's a C variant, or E/F. But wouldn't b e to hard to modify the plans.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 30, 2015, 01:26 PM
invertmast is online now
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
considering the articles with the F18 build is from 93, its probably an A/B/C variant, as they didn't have super hornets then
invertmast is online now Find More Posts by invertmast
Old Aug 29, 2015, 09:27 PM
Joined Jun 2015
finding Plans...
CoolerByTheLake, how would I go about contacting the member in the thread? there is no link or continuation of the thread to send a message.?
Old Aug 30, 2015, 12:50 AM
Joined Dec 2008
He's a member of RCG--just PM him.
Old Sep 25, 2015, 08:55 PM
Joined Jun 2015
F-18c Drawings
I found an old military magazine with scale drawings and enlarged them with an overhead to 1/10th scale. I am still working on the drawings and trying to figure out how to do the wings, vertical and horizontal stabs. When I get it completed, I figure to put two 70mm fans in it. Wish me luck.
Old Sep 25, 2015, 10:15 PM
Joined Dec 2008
James Rhodes, I'm no expert an this--but I have 2-- Y/A F-18 kits to work on over time.. These to, are 1/10th scale, see specs- http://yellowaircraft.webs.com/fa18hornetsingle.htm
And they call for a 127mm fan, with min 12+ - lb or better installed thrust,
For mine I'm having a custom made Neu hybrid motor built using the -1917/1Y stator with a 1915 rotor, which should give me Kv around 640. on 12s For my Tams/Dynamax fan
B-4 you go out and buy the fans/motor combo-Do some serious home work on this. Get as close as possible to expected AUW.
ALL components Then factor in costs! Feel free to PM me if you think I might be of some help,
Cooler
Old Sep 26, 2015, 11:11 AM
Joined Jun 2015
If I could get just the Yellow Aircraft F/A-18 Hornet Single -Primed, Carbon-Reinforced One Piece Epoxy Fiberglass Fuselage with All Panel Lines, Grills, Avionics, and Gun Details only along with the pieces for the control of the vertical and horizontal stabs and ailerons. I would use the ribs I have done for the internal to make it a twin 70mm. Do you know where I can get what have mentions? I already have scale gear from R/C Crafters. Checked out SLUF7 thread and found the plans he used from Triplet Publications for $33; not bad! What do you suggest? Do you have pictures of your projects?
Old Sep 26, 2015, 04:16 PM
Joined Dec 2008
What your asking for is a full kit!
If you do ever find one--scrape the twin 70's idea. You'll have no room for the retracts. Unless your doing a belly lander! Even then, you won't have much room. I know , I have checked out both F-18 kits- --its made for the Dynamax fan --although you could go with a120 fan too. With a ton of ducting mods --I thought about it, but my ducting skills suck-- so I bought another Dynamax fan, A Tams's center body, and am waiting on a special made Neu motor for one of them . The other gets a Dyn-E-max/Scorpion 635 Kv set up.
But I do have XPS/Dynamax -640Kv hacker I would sell you.
Don't even ask--....
There' s not a snows chance in hell I'd sell either one!
Old Sep 28, 2015, 02:07 PM
Ceeray is offline
Find More Posts by Ceeray
Finland
Joined Jul 2004
http://www.therccustomjets.cz/en/
there is one nice f-18..
Ceeray is offline Find More Posts by Ceeray
Old Sep 28, 2015, 04:17 PM
kcolraw is offline
Joined Feb 2015
Still no super hornet plans.... damn.
Old Sep 28, 2015, 04:32 PM
kcolraw is offline
Joined Feb 2015
Just found this on ebay.
http://m.ebay.com/itm/1-9-Scale-F-18...703?nav=SEARCH
Old Oct 02, 2015, 07:58 PM
Zipman is online now
Find More Posts by Zipman
Zipman's Avatar
USA, NJ, East Brunswick
Joined Nov 2003
Originally Posted by kcolraw View Post
They are FREE here in PDF format.
http://www.rcgroups.com/forums/showt...354459&page=62
Post 925 and 926 smaller and larger.
Zipman is online now Find More Posts by Zipman
Discussion looking for balsa plans for a scale F-18 E\F kcolraw Scratchbuilt EDFs 6 Jun 28, 2015 02:26 PM
Question 3d printing molds for F/G parts? Artful Owl 3D Printing 0 May 29, 2015 06:14 AM
Discussion 1/48 scale plastic F-18 rc conversion outtacontrol Scratchbuilt EDFs 10 May 12, 2015 10:07 AM
Discussion looking for balsa plans for a scale F-18 E\F kcolraw Electric Plane Talk 5 Mar 28, 2015 10:39 PM
Discussion Motor/ESC for a custom 18 blade EDF 3d printed Harcoreta Electric Ducted Fan Jet Talk 19 Apr 29, 2014 08:04 AM
