Old May 10, 2014, 10:58 AM
AustinTatious is online now
Find More Posts by AustinTatious
AustinTatious
AustinTatious's Avatar
Hurst, Texas, United States
Joined Jul 2003
My latest hairbrained scheme
First off, this doesn't really accomplish much, if anything in the way of performance. This is just something different and fun with a few small bonuses and a few perils that will need experimentation to eliminate.
A picture is worth 1000 words so here you go. Not to scale or final.
this is a VERY tiny winch attachment for a very small servo... It is to be run with a pull/spring setup.
The line would come from the tail surfaces through a guide tube then to the drum with 1 wrap and then through a hole in the upper drum lip and then to the servo screw for securing and easy adjustment.
What does this accomplish?
Its cool!
very clean looking installation
the moving parts do not displace additional space when they move
the amount of line pull is completely linear
can increase throw on servo to get higher resolution on the flying surfaces
more torque ( which means less current draw in all conditions)
probably lighter than a traditional horn
Things to worry about:
Line coming off of drum with a slacked line....
I am going to experiment with this. I am hoping that with a proper guide tube setup this will not be an issue. The guide tube could be cut with a 45 degree angle and positioned VERY close to the inner part of the drum.
AustinTatious is online now Find More Posts by AustinTatious
Old May 10, 2014, 11:03 AM
RubSon is offline
Find More Posts by RubSon
Aeromodeller by heart!
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Cool idea!
Maybe the drum needs to be a Little bigger to get enough deflection.
In a pull/spring setup, just wrap the pull-line two times around the drum. It´ll take care of any slack. (The line would be under tension at all times.
Ruben
RubSon is offline Find More Posts by RubSon
Old May 10, 2014, 11:05 AM
AustinTatious
Joined Jul 2003
Originally Posted by RubSon View Post
Cool idea!
Ruben
the idea is to go to roughly 150% on the throws (120 degrees of travel) and then size the elevator horn accordingly if needed.
Old May 10, 2014, 12:14 PM
RubSon is offline
RubSon's Avatar
Herning, Denmark
Joined Dec 2002
Makes sense.
In my case, I can only go 110% on the throws, but sizeing the horn is allways an option.
Are you planning on printing or milling the pieces?
Ruben
Old May 10, 2014, 12:21 PM
Airbud is offline
Find More Posts by Airbud
Airbud's Avatar
Canada, BC
Joined Jan 2010
Very good. I like it.
Airbud is offline Find More Posts by Airbud
Old May 10, 2014, 01:11 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
What benefit will linear servo travel offer when the receiving end is still not linear?
sp00fman is offline Find More Posts by sp00fman
Old May 10, 2014, 01:18 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
Maybe a matching +/- 30 or 45 degree pulley style horn with a string attachment for pull/spring at the surface end? Linear at both ends then. A lot of full-size aircraft control systems work like that, before hydraulics and such.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old May 10, 2014, 01:50 PM
jsmillett is offline
Find More Posts by jsmillett
Cerritos, CA
Joined Nov 2004
Think of it as a little built in exponential. Unless the control system has massive deflection it won't be all that much.
A typical setup with large angular servo throw (short servo arm) and smaller angular surface throw (longer control surface arm) results in some negative exponential that probably could use some positive transmitter exponential to even out.
jsmillett is offline Find More Posts by jsmillett
Old May 10, 2014, 04:43 PM
jcats is online now
Find More Posts by jcats
Launch high. Fly low.
United States, CA, Lake Elsinore
Joined Aug 2003
Its cool!
I like.
Please keep us updated.
Jun
jcats is online now Find More Posts by jcats
Old May 10, 2014, 04:53 PM
AustinTatious
Joined Jul 2003
Very good point. as stated this is mostly for cool factor.
However, by making a longer control horn you minimize that factor.... You would also minimize it on the servo end with a long arm, but the cost you pay are very apparent in that setup.
Old May 10, 2014, 05:36 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
About 30 years ago I did something similar, using pull-pull. I did it for rudder on an attempt at an F3B plane. I used center hinge, and a drum buried in the hingeline. That let me get all the control connections internal for minimum drag. It worked pretty well actually, but the hingepoint had to be solid near the drum to take the forces involved. Stab was full flying, and wing surfaces were sealed with no external linkups. It was pretty clean.
Gerald
G_T is offline Find More Posts by G_T
Old May 10, 2014, 05:40 PM
aftica is offline
Find More Posts by aftica
Plastic Buddha
aftica's Avatar
Joined Oct 2005
That is a very cool idea bro!
Worth it just for the compactness factor if you ask me.
If you could guarantee 1/4 gram weight savings, guys will wet their pants!
aftica is offline Find More Posts by aftica
Old May 18, 2014, 06:51 PM
AustinTatious
Joined Jul 2003
Ok, well.... I have been trying to get this part made with no luck from the guy I was trying to work with. (I'll keep quiet on who, cant really blame him!)
However, I think I have found a very easy way to accomplish this, perhaps not as pretty but just as effective and best yet, it wont cost you but a few pennies if you want to do it.... It is also the lightest possible way to accomplish this setup....
Ill be putting mine together like this very soon and will report on how well it works.
Setup: A hole is drilled through the servo output spline towards the bottom near the top of the servo. Heat shrink tubing is put around the spline and shrunken, then trimmed flush with the top of the spline and the parts of the HST covering the drilled holes is removed.
A washer with a diameter = or < the width of the servo and with a hold large enough only for the shaft of the servo arm screw is drilled with a small hole near where the servo spline ends.
The pull spring line is run 1-2 wraps around the shrink wrapped spline, through both holes in the splin, up through the hole in the washer and then wrapped around the screw. The screw is tightened to secure the line. This can serve as an adjustment point.
Old May 18, 2014, 09:12 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
I'd put a washer on the bottom also, just to make it harder to jam the thread.
GaryO is offline Find More Posts by GaryO
Old May 18, 2014, 09:58 PM
AustinTatious
Joined Jul 2003
there will still be a guide tube on the line glued to the flat spot of the servo. there wont be any way for it to get caught in there.
Gallery My latest work RC jetfoil " friend " y.takahashi Scale Boats 2 Oct 19, 2013 09:58 AM
Discussion My Latest Acquisition rcjake Fuel Plane Talk 6 Oct 07, 2013 11:08 AM
Discussion My latest whacky Thermal Dancer scheme... Hostage-46 Thermal 13 Jan 29, 2008 07:14 AM
Cool My latest Ion paint scheme SMITHB Electric Heli Talk 3 Jan 29, 2006 12:20 PM
