Old Apr 18, 2014, 07:58 AM
Joined Apr 2014
how to charge my battery?
how to charge it.. what settings to set on my charger ?how to wire it?
(hyperion 6060i)
(selling all my extra lifepo4 tenergy cells.18cells.send me PM offer.)
fonex is offline Find More Posts by fonex
Old Apr 18, 2014, 08:02 AM
United States, MN
Joined Feb 2011
Based on your picture that would be a 1s3p pack. What voltage are the cells though?
If each cell is 3500mah then for 1C charge rate you would set charger for 1s (voltage?) and 10.5A charge rate.
If pack as a while is 3500mah then for 1C charge rate you would set charger for 1s (voltage?) and 3.5A charge rate.
Since it is a 1s pack all you need to connect is the positive and negative. There is no balance leads.
But without knowing voltage though you can't set the charger quite right.
grimbeaver is offline Find More Posts by grimbeaver
Old Apr 18, 2014, 08:21 AM
Joined Apr 2014
i need to connect 2 of them same time..so i need to wire balance, the balance wires do not charge? must connect also the red and black ?
i still didnt understand what C to select for charging - how much Mah that mean ?
thats my battery detailed specification:
Title
Specifications of IMR MNKE 26650 Lithium battery
Rated Capacity
3500mAh (0.5CA Discharge)
Rated Voltage
3.7V
Internal Resistance
≤100mΩ (with PTC)
Cut-off Discharge Voltage
2.75V
Charge Upper Limit Voltage
4.200.05V
Charging Time(Std)
4.0hours
Standard Charging Circuit
0.2C A
Charging Circuit
0.5C A
Standard Discharging Circuit
0.2C A
Fast Discharging Current
0.5C A
Max Discharging Current
2C A
Old Apr 18, 2014, 08:49 AM
United States, MN
Joined Feb 2011
Connect all positive and negative together in PARALLEL exactly like you show in your picture. Then connect to positive (top of picture) and negative (bottom of picture) to charger positive and negative connections. No balance wires.
Set charger to Lipo 1s 3.7v and rate is going to be 700mah x number of batteries. So if two batteries then 1400mah. If three batteries then 2100mah.
Old Apr 18, 2014, 09:01 AM
Joined Apr 2014
i have 2 packs how to connect and what settings to select
Old Apr 20, 2014, 09:20 AM
Joined Apr 2014
Old Apr 20, 2014, 11:40 AM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
I'm sure he meant 700ma (0.7A) instead of 700mah as the charge rate.
If you are connecting them in parallel then it would be 0.7A x 2 = 1.4A.
Some information worth reading. this article and this safety guide.
hoppy is offline Find More Posts by hoppy
Old Apr 20, 2014, 12:04 PM
Joined Apr 2014
how did you know this type battery need charging rate 0.7A
Old Apr 20, 2014, 12:44 PM
Joined Feb 2008
It looks like that came from your specs:
Rated Capacity
3500mAh
0.2C A
So: 3500mah * 0.2C = 700ma.
Dave H. is online now Find More Posts by Dave H.
Old Apr 20, 2014, 04:04 PM
Joined Apr 2014
its the max 700ma ? i can do it slower ?
Discussion Can I charge my Turnigy 2200 9XR battery with my Accucel6 charger? 335Dude Batteries and Chargers 3 Jan 09, 2014 11:28 AM
Discussion Dewalt 14.4v How to charge it with my lipo charger? ChiTownFlyer Batteries and Chargers 4 Nov 09, 2013 01:03 AM
Discussion My S107G won't charge after battery replacement ldtheoson Coaxial Helicopters 10 Oct 18, 2013 10:18 AM
Help! Charging my lead acid batteries Liam.great98 Batteries and Chargers 8 Oct 07, 2013 04:09 PM
Question Will this wall-wart charge my battery? If so, how long to charge? magic612 Batteries and Chargers 9 Jun 15, 2006 11:54 AM
