Old Jan 06, 2013, 05:30 AM
FPV!
pisagor's Avatar
Joined Feb 2007
Question
carbon rod into the wing
How can i like that
quote picture:http://fpvlab.com/forums/showthread....-2-x-3s3300mah
pisagor is offline Find More Posts by pisagor
Old Jan 07, 2013, 11:05 AM
Bing44's Avatar
United States, OR, Independence
Joined Feb 2008
I'm not sure what you're asking, but if you want to know how to embed the carbon rods like the ones shown, short of there being holes already there, you can slice the foam down to the same depth and shove the rods in, then glue them in with your choice of glue. I like hot glue for this.
jim
Bing44 is offline Find More Posts by Bing44
Old Jan 07, 2013, 08:24 PM
FPV!
pisagor's Avatar
Joined Feb 2007
I want to ask how can i pierce my wing as the photo. I cut the wing and i want to pierce for the carbon roads .
Old Jan 09, 2013, 06:01 PM
Mum is the word!
Joined Jun 2003
Its top secret!
klique is offline Find More Posts by klique
Old Jan 14, 2013, 03:51 PM
FPV!
pisagor's Avatar
Joined Feb 2007
Originally Posted by klique View Post
Its top secret!
okay I'm gonna find my own method.
Old Jan 16, 2013, 03:47 AM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Try asking in the builders workshop,sure you'll get all the advice you need.
Stupot46 is offline Find More Posts by Stupot46
Old Jan 17, 2013, 02:52 AM
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
The optimal place for the carbon is along the top and bottom at the surface of the wing on the high point - not through the centre.
Running parallel to the leading edge from root to tip and joining the wing with a glass fibre wrap band.
Chases for the 1.5mm rods can be sanded, then place a thin line of polyurethane in the dampened chase and cover with a layer of tape to limit foaming, or use epoxy resin. A fibre reinforced tape or carbon ribbon spar can be used top and bottom to similar effect.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Jan 18, 2013, 09:04 AM
fliteline dave's Avatar
Canada, BC, Comox
Joined Jan 2011
carbon rod not a good choice
carbon rods will not give you any flex resistance use flats ether into slits top and bottom or ribons top and bottom i like full spars made out of flats placed at full cord running the full length of the panels and one across the rear where you have your rods nice cut on the foam
good luck
Dave
fliteline dave is offline Find More Posts by fliteline dave
Old Jan 18, 2013, 06:01 PM
Rusty
Rusty Nail's Avatar
Joined Feb 2006
Dave, 1.5mm rods are used in many Discus Launched Glider wings because they are cheap and quick to use. These are amongst the most stressed and thinnest wings in the model world!
Slits (or webs) will not give required bending strength unless very thick, it is the flanges of the I beam that generate the strength, the web should only hold them apart. The foam is usually enough for this, although weblets are sometimes used in light foam.
Old Jan 23, 2013, 05:57 PM
Canada, BC, Comox
Joined Jan 2011
EPP foam sucks as a separator for carbon and does not come close to webbing used when building free flight wings to separate the carbon foam is to soft your rods will bend the foam and will give you flex in your build that's just how it is i like solid carbon spars 12mm x 1mm 0 flex period a little bi directional tape sheet with new stuff no twist simple
this is how i build you may try whatever you like i was just giving you my opinion as your method was how i have built in the past and was unhappy with flex the result was that i went with solid spars they just work better
Good luck
KISS
Dave
Description: slice the foam through where you want a spar glue back together simple 0 flex
Found Wing Rod, 5/8" dia. Carbon Lutmi58 Aircraft - Sailplanes (FS/W) 0 Sep 05, 2012 02:58 PM
Question Where to put carbon fiber rods in easystar wings? easystarfpv4 Electric Plane Talk 3 Jun 27, 2012 08:11 PM
Question Putting carbon rods into foam cores lataj Hand Launch 12 Jun 21, 2011 11:50 AM
Question Carbon strips vs. carbon rods in EPP wings FTWORTH FLYER Power Systems 1 May 04, 2004 03:42 PM
