Old Dec 09, 2012, 06:35 PM
Eastern PA
Joined Feb 2011
Question
Topmodel CZ Adriana build - no pull string in wing
I'm starting to build the Adriana from Topmodel. Currently working on the wing servo install. There is no pull string to fish the wires through the ribs (wings are already monocoated). I was going to use a thin servo control rod to fish through the ribs, but the wire path doesn't exit straight at the wing base, so that won't work. Wondering if this is how they ship the ARF's, or are they missing?
Any suggestions would be appreciated.
rabshell is offline Find More Posts by rabshell
Old Dec 09, 2012, 08:39 PM
United States, IA, Urbandale
Joined Oct 2002
Tie or glue a small piece of lead to a light string. Now you can move the wing in various directins to allow the lead to fall through the ribs from the servo opening to the wing root opening.
airporter is offline Find More Posts by airporter
Old Dec 09, 2012, 11:27 PM
Eastern PA
Joined Feb 2011
Got it. Drilled a small hole in fuse end of wing, was able to slide a thin control rod through. Taped monofilament to it and pulled it back. Worked good.
Build Log New Swish Electro Glider By Topmodel cz **** Joe Pierson Electric Sailplanes 34 Aug 18, 2014 03:20 PM
Help! Topmodels.cz Chimera brushless motor austin.laws Electric Plane Talk 4 May 20, 2012 12:16 PM
Sold Adriana from Topmodel CZ Sotos Aircraft - Sailplanes (FS/W) 9 Feb 12, 2010 07:09 PM
Discussion How to fish aileron wire thru pre covered wing (no pull string) Txtoby Fuel Plane Talk 24 Aug 23, 2008 02:44 PM
Alert TOPMODELS CZ CAP 222 wing failure!! RICRAC Competition Aerobatics 8 May 07, 2008 04:04 PM
