Old Dec 07, 2015, 12:48 PM
qwerty1000 is online now
Find More Posts by qwerty1000
qwerty1000's Avatar
Russia, Moscow, g. Moskva
Joined Sep 2007
A10 AeroTetris
hi all
new development
wingspan 2200mm
2Х120EDF
Best Regards, Egor
qwerty1000 is online now Find More Posts by qwerty1000
Site Sponsor
Old Dec 07, 2015, 03:31 PM
SwaFly is offline
Find More Posts by SwaFly
SwaFly's Avatar
Belgium, Brussels, City of Brussels
Joined Apr 2011
Can't wait to get mine Egor!
SwaFly is offline Find More Posts by SwaFly
Old Dec 07, 2015, 06:16 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Nice! Although I think twin 90's on 6S would be plenty of power
4stripes is offline Find More Posts by 4stripes
Old Dec 08, 2015, 02:45 AM
Mr. UD is offline
Find More Posts by Mr. UD
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
...do you still keep my "wishlist" in mind santa Egor?
(do you need coordinates for the NACA 5515 and NACA 5513?)
Originally Posted by Mr. UD View Post
Hello Egor,
if it is not to late, may I place some structural wishes for the 2200mm A-10?:
Fuselage:
  • wall thickness: 10mm
  • room for 3 10mm tubes at left/right bottom corner and top of cross section (see picture)
Wing:
  • NACA5515 from center line to begin of taper
  • NACA5515 at root of tapered section
  • NACA5513 at wingtip
  • wall thickness: 7mm
  • 10mm wide "spar" at 33% of length
  • "massive" trailing edge beginning at 66% of length
Horizontal and Vertical tail:
  • NACA0009
  • wall thickness: 5mm
  • 5mm wide "spar" at 33% of length
Armament:
please design the bombs and rockets as hollow shells with a wall thickness of 5mm - or the bird will be much too heavy to fly with full ordinance
Please do not model the fins - wasted time - these are better made of cardboard, thin ABS or GfK or even Balsa.
I guess you will sell more kits if you offer the weapons-kit seperately. Scale is 1/8 (1/10; 1/12) which is common - so the weapons kit can be used for other planes as well. I would buy at least one more for my FlyFly Hawk and my two HobbyTopgun L-39's
  • Station 1: ECM-Pod (AN/ALQ-184)
  • Station 2: empty, 1x CBU-100 MK20, single or double AIM-9 - whatever you want
  • Station 3: 3x Maverick AGM-64 (triple Launcher)
  • Station 4: 1x GBU-10 Paveway_II
  • Station 5: 6x dispenser with 6x MK-82
  • Station 6: empty
  • Station 7: 6x dispenser with 6x MK-82
  • Station 8: 1xGBU-8
  • Station 9: 3x Maverick AGM-64 (triple Launcher)
  • Station 10: empty, 1x CBU, single or double AIM-9 - whatever you want
  • Station 11: ECM-Pod
Version:
Would it be possible to add a second canopy to build a YA-10B alternatively?
Mr. UD is offline Find More Posts by Mr. UD
Old Dec 08, 2015, 03:56 AM
qwerty1000's Avatar
Joined Sep 2007
Thanks Mr Ud!
post here everything you you think is right
RegEgor
Site Sponsor
Old Dec 08, 2015, 05:14 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Summary Optional weapons-kit:
(I would buy at least one more for my two FlyFly Hawk's and my two HobbyTopgun L-39's )
The weapons kit should include:
2x ECM-Pod AN/ALQ-184
6x AGM-65_Maverick on 2x triple launchers (launchers not necessarily included because they are hard to build and too fragile if made out of foam)
12x MK82 for 2x 6-dispensers (dispensers also not made out of foam)
1x GBU-8
1x GBU-10 Paveway II
2x CBU-100 or 2x AIM-9 or 4x AIM-9 on double launcher (4xAIM-9 maybe best option if the kit is used for other planes)
modeling:
Old Dec 08, 2015, 05:25 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
...below the profile coordinates for the NACA 5515 and NACA 5513 in case you don't have them already
Old Dec 08, 2015, 09:20 AM
qwerty1000's Avatar
Joined Sep 2007
hi all
5513 and 5515
RegEgor
Site Sponsor
Old Dec 14, 2015, 06:39 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Hello Egor,
if (still) possible: do you think you can let design the nacelles like shown in the attachment?
It uses a foam tube (which houses the ESC) to reduce outlet area without narrowing the outer diameter of the nozzle.
The diameters are calculated to result in an outlet area which is equivalent to a nozzle diameter of ~100mm which is recommended by ejets for the JetFan 120mm eco.
Rear part of the nacelle is designed as hollow shell - A-10 will be hugely tail heavy - so every single gram saved in the tail will save several grams in the nose
Old Dec 16, 2015, 05:13 PM
qwerty1000's Avatar
Joined Sep 2007
hi mr UD
Good!
we make changes.
I think, to make two decisions.
1. straight pipe
2. bent pipe
Our 3D model is ready, we will soon begin to prepare the file for CNC
Best Regards, Egor
Site Sponsor
Old Dec 17, 2015, 10:50 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
Mr UD, where did you get that picture of the nacelle cutaway? is there some A-10 kit that has flew under my radar?
Egor, any chance of an isometric view from the front and solid rather than wireframe?
Dirty Dee is offline Find More Posts by Dirty Dee
Old Dec 18, 2015, 01:58 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Did the drawing on my own to clarify my wishes
@Egor: any idea already about the cost? Maybe there might be enough in my wallet for one more plane at your black Friday sale
Old Dec 18, 2015, 03:52 AM
qwerty1000's Avatar
Joined Sep 2007
I am sure that your wallet will not suffer.
in this thread for modellers, I do discounts more than Black Friday
we are still working.
I hope to show in this year
Best Regards, Egor
Site Sponsor
Old Dec 19, 2015, 07:36 AM
amigob is online now
Find More Posts by amigob
Netherlands
Joined May 2009
Mhh, now you have my attention :-)
I already liked the P38D but this A10 is very interesting.
Wat kind of ready to flight weight are w talking about ?
amigob is online now Find More Posts by amigob
Old Dec 20, 2015, 12:35 PM
qwerty1000's Avatar
Joined Sep 2007
hi Amigob!
now we are nesting components. it is very time consuming.
and only then, after work of CNC machine, I would say, the final weight of the model.
now it is not known.
but traditionally, we will maximize lighter and robust model.
Best Regards, Egor
Site Sponsor
Build Log Aerotetris Boeing 747 Mankan RC Airliners (Commercial, Cargo, Troop Carrier) 171 Apr 07, 2016 08:41 PM
Discussion J-35 Draken AeroTetris/Bukvorez qwerty1000 Foamy EDFs 55 Apr 07, 2016 07:57 PM
Discussion JA-37 Viggen AeroTetris/Bukvorez qwerty1000 Foamy EDFs 153 Apr 03, 2016 11:01 AM
Discussion Viper MK-IV AeroTetris / Bukvorez qwerty1000 Foamy EDFs 12 Oct 26, 2015 08:21 AM
Discussion Boeing 727-200, Aerotetris qwerty1000 Large EDF Jets 17 Apr 29, 2015 12:23 PM
