Old Sep 15, 2015, 02:55 PM
BlueLightSpecial is offline
Find More Posts by BlueLightSpecial
United States, PA, Gibsonia
Joined Sep 2015
First time builder
Im a 40 yo noob, learned on a Champ, finally decided to graduate to something with ailerons. So I purchased a Red Eagle Aurora from value hobbies. Began assembly, Wing went ok, but my question is the foam pieces that contain the carbon rods and attach to the main fuselage on both sides, strengening it. Once I glued these pieces in place, I noticed that the main fuselage has an ever so slight curve to it. Maybe I'm being too critical, but is this going to be a problem? I havent assembled the tail, so perhaps once that is finished, it will be PERFECTLY straight. Thanks in advance!
BlueLightSpecial is offline Find More Posts by BlueLightSpecial
Old Sep 15, 2015, 04:34 PM
PaulB is online now
Find More Posts by PaulB
Mike's Ma Maaaaaaaaan
Paderborn DE
Welcome to RC Groups (I would have said 'Hi XXXXX but you didn't post your name....).
A bow in the fuselage however slight will obviously cause a tiny problem, it will effectively give you a bit of unwanted rudder all of the times, but you have a trim button, right?? Just trim it out IF you notice it.
HOWEVER, bet you never notice it and will be 10000% happy with how your Baby flies. Learn for next time but don't worry, models can often fly pretty good with a slight 'bent bit', the biggest problem is when the pilot gets it into his head that it won't fly....
Don't sweat it, go fly and have fun,
Paul
PaulB is online now Find More Posts by PaulB
Old Sep 16, 2015, 07:10 AM
Joined Sep 2015
Thanks for the reply, Paul! My name is Josh, by the way! Im hoping that when I assemble the tail, that the tail will pull it all together! I can't wait to finish the build and put her in the air! The more I look at it, the straighter it looks so I am thinking it will be ok! Thanks again!
Old Nov 27, 2015, 07:24 PM
Joined Sep 2015
Ok, as life would have it, I haven't finished my build. I'm sure most of you can assemble this plane in a few hours. But, life's crazy schedule has me in a holding pattern. My question is, what does the rudder use for a hinge? The vague directions show nothing on how to attach the rudder. The rudder is cut with a bevel running from top to bottom. Am I to just glue the point of the bevel to the fuselage? Or use some kind of fabric as a hinge? Totally new to this, don't want to screw it up. Thanks in advance!
Josh
Old Nov 27, 2015, 07:59 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
I think there were some hinges in the package. I used regular CA hinges as the supplied ones
looked a bit whimmpie.
Cut a slot in the rear of the fuselage and a matching slot in the rudder. I would use three hinges min.
I look for a picture.
The picture in the instructions is terrible so I did a drawing.
BHOFM is offline Find More Posts by BHOFM
Old Nov 27, 2015, 08:52 PM
Joined Sep 2015
Thanks! I'm out of town right now, but I will stop by the hobby shop for CA hinges. I don't recall seeing them in my kit, so I will just pick some up. Thanks again!
Old Nov 27, 2015, 09:34 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
They are really small and would be easy to over look. They were in the bag
with the Z bend ends.
Old Nov 29, 2015, 02:05 PM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
http://www.rcgroups.com/forums/showthread.php?t=2467143
this might help some
spaz
spastic is offline Find More Posts by spastic
Discussion Tip for first time build from a first time builder!!! Jim_W Multirotor Beginner 9 Feb 14, 2016 12:01 PM
Discussion First time builder questions -Dumas Chris Craft 1949 Racing Runabout sgerus Scale Boats 14 Sep 20, 2015 10:38 PM
Discussion First time builder needs your help. iBainesy Multirotor Beginner 0 Aug 13, 2015 04:54 AM
Discussion First kit for first time builder? angelix Scratchbuilt Indoor and Micro Models 5 Jul 15, 2014 06:12 PM
Discussion ARF Kit for First Time Builder gordonzo Beginner Training Area (Aircraft-Electric) 5 Oct 27, 2013 09:06 PM
