Old Jun 12, 2016, 09:36 AM
KenS999 is offline
Find More Posts by KenS999
KenS999's Avatar
United States, IL, Huntley
Joined Oct 2008
Question
Help with Wing Issue
Hi,
I was given a 900mm TELINK TORO foam wing. Power train is 2200kv motor, 8 x6 prop, 1300mah 40c lipo. Wing flies ok at low speed, but when I throttle up, the wing goes into an uncontrollable spiral and heads for the ground. This has happened numerous times. The only way to get out of the spiral is to pull the throttle back to idle and attempt to steer out of the spiral. Is this problem a result of too much torque created by the motor/prop? It does happen every time I try to fly with some increased speed.
thanks,
Ken
KenS999 is offline Find More Posts by KenS999
Old Jun 12, 2016, 09:53 AM
Clive66 is online now
Find More Posts by Clive66
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
Might be slightly tail haevy.
I would try adding a little nose weight (maybe 1/2 ounce) & see if that makes a difference.
Another thing to check would be the motor thrust angle.
If the mount was ever damaged, maybe it wasn't repaired correctly.
Clive66 is online now Find More Posts by Clive66
Old Jun 12, 2016, 11:11 AM
KenS999 is offline
KenS999's Avatar
Joined Oct 2008
Thank you.
Old Jun 12, 2016, 11:39 AM
goldguy is online now
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Motor thrust angles wrong.
When viewed from the back, the motor should be tilted to the right and the top of the motor forwards.
goldguy is online now Find More Posts by goldguy
Old Jun 12, 2016, 12:32 PM
Clive66's Avatar
Joined May 2011
Ken:
Here is a thread on the TORO
http://www.rcgroups.com/forums/showthread.php?t=1863060
Old Jun 12, 2016, 01:00 PM
KenS999 is offline
KenS999's Avatar
Joined Oct 2008
Will use a couple spacers to further alter correct thrust angle. Thank you.
Old Jun 12, 2016, 11:27 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Looking at the plane, and the power system it was designed for, my guess is you're dealing with flex in the elevons, or even the wing itself. Weak linkages or servos could also be the culprit.
Bad thrust angles can make a plane behave poorly, but you'll be fighting them every second the motor is on... or more commonly, you'll trim the plane to fly under power, then fight it ad nauseam in a glide. In any case, a sudden+complete loss of control is very unlikely to stem from a thrust angle issue.
Piece is offline Find More Posts by Piece
Old Jun 13, 2016, 01:30 AM
nuteman is offline
Find More Posts by nuteman
Joined Apr 2013
I'm with Piece on this. The motor for that plane is mounted in the same plane as the wing itself (not on a stalk way above or below the wing). It is exceedingly unlikely that thrust angle is responsible for the behavior that you described. If it was ridiculously off, you'd see the behavior way before you ever got a chance to get it up to higher speed.
The sudden departure is more likely related to flex in the wing or linkages as Piece said.
nuteman is offline Find More Posts by nuteman
Discussion Help with hexa! Poss. motor, ESC, naza or user issues? Grainde Multirotor Beginner 9 May 17, 2016 01:49 PM
Help! Help with weird print issue. bluemeane 3D Printing 5 Feb 15, 2016 09:01 PM
Discussion HELP 2nd FT012 with power issue cheynespub Racing Boats - Electric 7 Oct 20, 2015 11:02 PM
Discussion Dji F450 issues with gimbal please help Jaybe1 Multirotor Talk 2 Sep 17, 2015 02:23 AM
Discussion Blaster Wing issues - Help needed with first glider build shansiden Hand Launch 16 Mar 05, 2014 11:06 AM
