Old May 02, 2015, 02:08 PM
jpdenver is offline
Find More Posts by jpdenver
Son of a Sailor
jpdenver's Avatar
United States, CO, Denver
Joined Jan 2014
Question
Building techniques
Greetings,
I am building the Krick Borkum (see my build thread) and I am just getting started on the hull assembly. I have some questions to ask the experienced builders:
1. Do you coat - paint/varnish - ALL exposed wood? I am mostly concerned about
the undersides of decks, hidden sides of bulkheads etc.
2. Do you varnish before glue - or after glue?
3. Do you Varnish the Deck Planking before gluing?
4. Do you stain pieces before gluing?
5. Does Titebond work over varnished wood?
6. Does Titebond work over stained wood?
7. Are there any combinations that come to mind that are "deadly"
(like they melt an ABS hull)?
8. My Hull is ABS - it is getting dusty/dirty - what will clean it best, what do I stay away from -
- mineral spirits?
- alcohol?
- naptha?
- lighter fluid?
- acetone?
Thanks for reading,
Jim Pope
Denver
jpdenver is offline Find More Posts by jpdenver
Old May 02, 2015, 11:03 PM
SenorNeekers is offline
Find More Posts by SenorNeekers
Steamy laser dude.
SenorNeekers's Avatar
Canada, BC, Victoria
Joined Oct 2011
Titebond works best on bare wood. But if you glue before you stain, the glue will likely interfere with the finish.
Sealing all surfaces of wood isn't likely necessary, but certainly won't do any harm. It's simple, and may prevent serious issues later on.
I would suggest staining everything first, and varnishing after assembly is complete. That's just what I like.
I'd steer away from acetone for cleaning the hull. Alcohol or dish detergent should suffice.
SenorNeekers is offline Find More Posts by SenorNeekers
Old May 04, 2015, 02:02 PM
CM Cheng is offline
Find More Posts by CM Cheng
Hong Kong
Joined Dec 2003
Hi Jim,
Below are what I did in building my Borkum. Hope it helps!
1, I paint all the exposed woods. For the hidden parts I used white acrylic paint instead of clear vanish so I am sure they are all covered.
2, Vanish after glue.
3 and 4, No. I think wood-glue-wood gives the best bonding.
7, Acetone dissolve ABS efficiently! See below my home made "ABS glue" used in 3D printing!
8, I used alcohol to clean the hull, then wet sand it with #400 before painting.
Cheers,
CM Cheng
CM Cheng is offline Find More Posts by CM Cheng
Old May 04, 2015, 09:55 PM
jpdenver is offline
Son of a Sailor
jpdenver's Avatar
Joined Jan 2014
I am beginning to attach the "decking" or "cladding"
"Patience is a virtue" - plan, dust-off, measure three times, cut only after
you exhale.
Do not forget to sand before you finish - I won't again.
My UHU glue showed up from the UK today - so back to the build thread.
Regards,
Jim Pope
Denver
Discussion Best Balsa Wood Building Technique JoDoggie Dock Talk 14 Feb 09, 2015 07:18 PM
Discussion "Clean" building techniques? Build Tips/Tricks! UberNiK FPV Aircraft 2 Feb 06, 2015 09:00 PM
Discussion B-18 Bolo new build technique...for me at least. rc capo Foamies (Scratchbuilt) 0 Aug 05, 2014 09:26 AM
Discussion Index of Building Tips, Tools and Techniques Steve85 Scale Kit/Scratch Built 4 Jul 03, 2014 10:11 PM
