Old Feb 12, 2008, 03:30 PM
cos918's Avatar
abingdon england
Joined Feb 2008
Build Log
celestine
hi all. I am new here.
Well to start heres a few photos of my ferry boat . Now i am starting to rebuild her as i was not happy with her.
john
cos918 is offline Find More Posts by cos918
Old Feb 12, 2008, 03:34 PM
Long Island,NY
welcome and i love that boat it really looks cool....does the loading door work? if so it would be really cool if it carried micro ts or some other rc car
mrwuffles is offline Find More Posts by mrwuffles
Old Feb 12, 2008, 03:51 PM
cos918's Avatar
abingdon england
Joined Feb 2008
i am working on it but it hard to find photo of the real ferry with her rear stern door down. I like the idea of one of thoes revell 1:87 scale rc trucks coming out of the back of her at a show.
john
Old Feb 12, 2008, 04:01 PM
Long Island,NY
id think it would be that hard to make what is the door made out of? and how big is it
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Hi cos918
On the upper deck of cars, the back row looks like a row of Mini's... The proper one's, not the BMW small car...
Do i spy a couple of Vans, at least one pick up and a... woody?
toesup is offline Find More Posts by toesup
Old Feb 12, 2008, 04:02 PM
r/c ships and workboats
bellingham, wa
Joined May 2006
Very nice model there cos918!
keith S is offline Find More Posts by keith S
Old Feb 12, 2008, 04:05 PM
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
john
Ghost has recently done a lowering 'lift' for a mini submarine on the back of his (re) build
http://www.rcgroups.com/forums/showthread.php?t=757017
Perhaps something similar in operation could be used to lower the rear door on your Celestine...
Old Feb 12, 2008, 04:19 PM
Long Island,NY
or he may be able to use sailboat winches and hook lines up to the ends of the door or just two servoes hooked up like a vertical rudder if u understand
Old Feb 12, 2008, 04:23 PM
cos918's Avatar
abingdon england
Joined Feb 2008
hi all and thanks for the repplys. OK toesup yes you are right they are orignal minis made by cararama at 1:72 scale and she is 1:100 scale a little out but they give a nice idea of what she should be like.
The door is one resine casting 22cms tall and 23 cms wide. I am making the hinge out of brass for strength. As for ghost lifting frame i have seen it on a diffrent forum. The problem i have is the photo of her are poor and its hard to tell if the door is lifted by cabels or hydrolics .
john
Old Feb 12, 2008, 04:34 PM
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Looks to me as if they are hydraulic...
Victorine
at Purfleet, 9th October 2004.
from http://www.simplonpc.co.uk/Cobelfret2.html#anchor342565
Old Feb 12, 2008, 04:40 PM
Long Island,NY
heres a good picture of her sister ship the valentine and it shows hydraulic arms in about the middle of the door to lower and lift
Old Feb 13, 2008, 10:03 AM
cos918's Avatar
abingdon england
Joined Feb 2008
hi big thank you to both toesup and mrwuffles , those photo are spot on how i can carry with the build.
john
Old Feb 17, 2008, 04:59 PM
cos918's Avatar
abingdon england
Joined Feb 2008
hi all. Well heres an update. First the base was made up from brass this gave a good strong point on the ferry for the hinge. Second the rear hinge was made up from brass 21 parts oh joy. Third made the top hinge that sits on top of the rear door. Fourth started on the hydrolic rams. Next job is to make a linear actuator to push the ram any idea are welcome .
john
Old Feb 17, 2008, 05:24 PM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Looks like a nice heavy duty hinge.
How about RC trucks?
http://www.hlj.com/product/KSH66084-40
http://www.hlj.com/product/KSH66084-49
Looks like most others are out of stock.
SDP-SI will have rack and pinions.
Look under Gears > Racks
https://sdp-si.com/eStore/
A modified servo, or sail winch could drive the pinion, and then the rack attached to the ramp rams.
I used an extended servo arm and control horn for my ramp.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Feb 17, 2008, 06:09 PM
Long Island,NY
that looks awesome i think the best thing to do would be to use a gear on each side w/ a sail winch like umi said another idea might be to use a normal servo like a steering servo or something and just have the hydraulic arms look like real ones thats what one guy did and it looked really real then all u need is some cars to drive on and off. and what did u make the door out of is it foam????
-mrwuffles
