Old May 06, 2014, 05:27 PM
Electric Airplane Junkie
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
Help!
Etched Teflon tubing
I am looking for some etched teflon sleeves for carbon pushrod, can anyone suggest a source?
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old May 06, 2014, 05:32 PM
a.k.a Frank Campbell
Long Beach, CA, USA
Joined Jan 2007
Brian, an EAJ
http://www.rcbuilder.com/Bulk-Bondab...wire_p_55.html
VintageFan is offline Find More Posts by VintageFan
Old May 06, 2014, 10:04 PM
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
Thanks. They have the 0.02" for steel wires. I am looking for the bigger one so I can use the 0.7mm - 1.0 mm carbon rods.
Brian, an EAJ
Old May 06, 2014, 10:08 PM
Stick Bangers Suck
racedouge1's Avatar
United States, CO, Golden
Joined Feb 2006
Try CST Sales... http://www.cstsales.com/pushrod_tube.html
racedouge1 is offline Find More Posts by racedouge1
Old May 07, 2014, 10:43 AM
Yes..ok..maybe..lol.....
Tucson Avra Valley, Arizona, United States
Joined Jul 2004
tailboom.com
shhhhh! is offline Find More Posts by shhhhh!
Old May 07, 2014, 11:05 AM
Thermal, where art thou?
BavarianCharles's Avatar
85045
Joined Oct 2005
The website "tailboom.com" is no longer functional.
You'll have to email Rick Walba directly: rawmr@yahoo.com and request available sizes and prices.
See this thread for making your own etched tubing:
[http://www.rcgroups.com/forums/showthread.php?t=1903224
BavarianCharles is offline Find More Posts by BavarianCharles
Old May 07, 2014, 11:46 AM
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
We sell Teflon (PTFE) tubing, and ship world wide:
http://www.hyperflight.co.uk/product...Teflon%29+Tube
I can give discounts on trade quantities.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old May 07, 2014, 12:03 PM
85045
Joined Oct 2005
Originally Posted by Neil Stainton View Post
We sell Teflon (PTFE) tubing, and ship world wide: http://www.hyperflight.co.uk/product...Teflon%29+Tube
I can give discounts on trade quantities. Neil.
Neil,
thanks for the info, and I'll keep you in mind for future purchases.
Would USA customers have to pay the VAT?
Old May 07, 2014, 12:16 PM
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
Neil,
Is the price on the teflon tubing per meter ?
Brian, an EAJ
Neil.
Old May 07, 2014, 12:21 PM
HyperFlight Support
Joined Feb 2001
No. The web site automatically deducts VAT for out of EU sales. (And also for within EU sales for VAT registered EU companies.)
Neil.
Old May 07, 2014, 12:23 PM
HyperFlight Support
Joined Feb 2001
Yes.
Old May 07, 2014, 06:15 PM
Thermaln2's Avatar
Reno Nevada
Joined Oct 2007
---Posted this in the Loctite 770 thread by mistake:
After looking at the MSDS sheets for components, the Loctite 770 is just a cleaner and CA amine accelerator. Basically it is the same stuff as the spray accelerator you buy at the LHS.
If Teflon is really "etched" it means that the carbon-fluorine bond is broken of the Teflon polymer chain and the fluorine atom is replaced by a bonding group. Bonding groups are generally hydroxyl groups or perhaps and amine group. This new side group is what actually bonds to the CA polymer glue and holds everything together. There are two ways to bond, you can either make a chemical bond, or you can disrupt the surface of the plastic polymers (essentially dissolving it) and then when the glue gets in the spaces the glue bonds.
I do not know how Teflon is etched, but generally etching of this type is done using a electric plasma of some sort, or by a dissolved sodium metal. This is done using something like Ozone, or another radical generator that breaks the C-F bond and does the replacement. Both are very bad to handle, VERY bad and HARSH.
If I were going to try to "etch" Teflon, one might try soaking it in hydrogen peroxide that yiou can get in the store. Also, you could soak it in MEKP (MethylethylKetone peroxide), the same stuff used to initiate polyester resin hardening. I am not sure of the if the "black" of etched Teflon is due to the etching process of white Teflon, but that could often be the case with reactions.
Other than that, there is not a lot of things you can chemically do to Teflon, it is very inert, but radical formation is very harsh, a very oxidizing and dangerous thing to do. MEKP can explode but is more stable than hydrogen peroxide when not in water. The etching might leave the surface of the Teflon as radical which then bond to the CA, hence the need to keep the etch Teflon. The Primer is an amine in Heptane (a carrier for the amine to keep it diluted). You could soak the Teflon in heptane that contains the peroxides, then wipe it off.
I am going to have to try this myself. But beware, everything is flammable.
If you still need etched Teflon, I have some on a roll that I have been using, but it is of a limited diameter inside. I normally use 0.025" wire inside and sometimes stretch out the tubing so it fits the wire with little slop.
OK, that's my thoughts.
Chris
Thermaln2 is offline Find More Posts by Thermaln2
Question etching of teflon tubing pyrsly Hand Launch 31 Apr 27, 2009 08:27 AM
Discussion Teflon tube etching Steven Bleazard Hand Launch 5 Feb 24, 2007 02:33 PM
Discussion Etched teflon tubing source? UnkyJack Hand Launch 4 Jan 31, 2007 08:41 AM
Discussion Etched Teflon Tubing Can I do It ? Air Head Hand Launch 7 Jul 31, 2006 09:42 PM
Etched Teflon Tube ClosetRCModeler Hand Launch 22 Jul 11, 2005 11:14 AM
