Old Feb 22, 2014, 08:30 AM
Joined Dec 2013
Fixing motor with motor mount
Hi Guys,
Regarding fixing this motor with a motor mount can someone suggest which one will fit my motor- keeping in mind the main barrel is what rotates and needs to be unobstructed.
uavuav is offline Find More Posts by uavuav
Old Feb 22, 2014, 09:27 AM
Su-27's Rule!
Su-33's Avatar
Philippines, NCR, Pasig City
Joined Nov 2012
i suggest using an x mount on a 90* ply reinforced triangle.
Su-33 is offline Find More Posts by Su-33
Latest blog entry: A cheap way to measure Kv
Old Feb 22, 2014, 09:31 AM
Su-27's Rule!
Su-33's Avatar
Joined Nov 2012
May i ask what is the application ?
Old Feb 22, 2014, 11:23 AM
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
It`s a boat, maybe something like this could work: Alloy_Motor_Mount_for_Boat_1pcs_bag_.html
MagnusEl is offline Find More Posts by MagnusEl
Old Feb 22, 2014, 01:41 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Something in this style? http://www.hobbyexpress.com/aluminum..._1365_prd1.htm
or maybe you can modify one of these: http://www.hobbyexpress.com/horizont...s_748_prd1.htm... a beam mount seems ideal for a boat!
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 26, 2014, 07:18 AM
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
A piece of aluminum angle stock with a few well-placed holes would do the trick.
Granted is offline Find More Posts by Granted
Old Feb 26, 2014, 07:50 AM
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
First of all, try to get rid of the cardan joint. These things never spin true at high RPM.
Best solution is to remove the motor shaft, and make the prop shaft longer, so that it replaces the motor shaft. Of course, the diameter of both shafts needs to match. But you will get no nicer running system than with this kind of setup.
If this should not work, replace the cadan joint with a joint having a piece of rubber in the middle, these things run very nice as well.
To fix the motor, buy a piece of FR4 material. These are glas fibre sheets normally used for PCBs or such. 1.5-2mm will do.
Cut a triangle with a round edge at the top, and make holes for the shaft and fixing bolts. Connect the motor, adjust angle and position,a nd glue to the hull with thickened epoxy.
This works particularly well with an aluminium flange.
Here are several images:
http://rc-powerboat-team-schleiden.j...-wellenanlage/
Julez is online now Find More Posts by Julez
Alert N.E. Illinois Univ. of Chicago: Monument to Abe Lincoln, Democrat craab Life, The Universe, and Politics 3 Nov 12, 2013 10:55 AM
Question Help needed to fix a problem with an FT Spitfire Snardo Foamies (Scratchbuilt) 7 Oct 18, 2013 01:32 AM
Discussion Broken upper ball joint on swashplate temporary fix [lama v3] sparkysko Coaxial Helicopters 0 Nov 12, 2007 01:59 AM
Question How can I fix loose ball-joint connections on my BCP? Crazyrcer Micro Helis 1 Aug 01, 2006 01:30 PM
How do you fix lose ball socket joints?? cat5 Micro Helis 7 Nov 01, 2005 05:34 AM
