Old Sep 21, 2014, 01:19 PM
Rugby, UK
Joined Feb 2007
Originally Posted by DamonH View Post
Are IR reading in the 4-5 mohm per cell high for a 6s 4000mah 60c battery? Thanks
Assuming you have taken the readings at a a reasonable temperature, ie about 20 - 22*C, then yes, the figures are high.
4.5 milliohms suggests a maximum safe current of 73A, representing a real 'C' value of about 18.
At 20 - 22*C you should see a cell IR of about 3 milliohms on a good lipo. Keep in mind that the IR is VERY temperature dependent .
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Old Sep 21, 2014, 01:23 PM
chuck
santa barbara, CA
Joined May 2009
i would say it depends on exactly how u got those #'s . best is to compare to a known good battery u have using exactly the same test. do u know about this: http://www.jj604.com/LiPoTool/
using this is a very good way to compare what u have to others in your stock. if the #'s u posted are accurate , using the tool, shows about 20 c real world . that's not bad if its a older battery , could be better if it's new , but very usable imo. yrmv.
chuck
chas650r is offline Find More Posts by chas650r
Old Sep 21, 2014, 03:39 PM
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Look through the IR recording on page 44, top right corner of the voltage screens (report #653)
http://www.rcgroups.com/forums/showt...767093&page=44
There's IR readings for comparison on 27 different packs (at storage, after charge, after run) so it gives you a pretty good idea on what you should see.
Joe
MCSGUY is offline Find More Posts by MCSGUY
Old Sep 21, 2014, 03:51 PM
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Thanks Joe!
DamonH is offline Find More Posts by DamonH
