Old Mar 17, 2012, 04:46 PM
Where is the inspiration
wdeighton's Avatar
Moira
Joined Feb 2006
Build Log
Groove Armada DP
After starting a thread a couple of years ago
http://www.rcgroups.com/forums/showthread.php?t=1299094
The itch has continued.
I now have some sort of a design, but still with no section confirmed for wing, stab or fin.
I have worked on my likes of the dynamics and kinetics, and added a bit of my own.
The initial design is for a 2m, with the idea to have a 2.5 on the same fuz.
Fuz is kept small but not too small.
moment of the 2m is quite long about the same as a dynamic would be, but with the 2.5m wing its more inline with the kinetic,
Still not sure if it will be T or X tail. i like the way I have it now, but its an extra mould.
Please feel free to rip it to shreds, and all ideas on wing sections will be greatly appreciated.
Will
wdeighton is online now Find More Posts by wdeighton
Old Mar 18, 2012, 03:42 PM
ETS....Energy retention system
timbuck's Avatar
gold coast australia
Joined Aug 2008
Looks nice will....subscribed..
So what's the deal..CNC. Mdf...corian..LG himacs...???
Tim
timbuck is offline Find More Posts by timbuck
Latest blog entry: Gizmo 36 pics
Old Mar 19, 2012, 02:26 AM
wdeighton's Avatar
Moira
Joined Feb 2006
Tim
Hello Tim
Depending on confidence and finance, I would love to make them out of a corian type of material, and cnc cut cavities. I had an offer a while back for some cheep cnc work, but the materials would still cost 1k for the lot. I am also considering using china to mill the cavities.
At the moment its all about wing stab and fin sections
After some feed back I will reduce the size of the fin by 10%.
The stab also needs a new plan form to bring it in line with the wing.
And it all needs a bit more finesse.
I also have access to 3d fluid dynamics with a bunch of university students, but unfortunately none of us know what we are looking for so still hoping to find some guidance with that.
William
Old Mar 19, 2012, 07:53 AM
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Interesting Y'know, there are some very accurate patern making methods that don't require CNC milling if cost is an issue. Only downside is you'll not be able to have a curved LE.
Shedofdread is offline Find More Posts by Shedofdread
Old Mar 29, 2012, 01:21 AM
wdeighton's Avatar
Moira
Joined Feb 2006
a Bit of an update
Been getting back in to this abit and attached is some ideas from a fuz perspective.
Trying to get the ratios between wing, stab and fin correct.
I quite like the sub fin Idea.
The canopy opening will be smaller then in the picture, with an insert to cover over that is screwed / glued in place. It will have the smallest hole required for your switch / plugs to power your model. and the canopy will cover the lot Flush. Only challenge here is to find a way to fix the insert to the fuz. My preference is lots of little screws.
Will
Old Apr 26, 2012, 03:05 AM
wdeighton's Avatar
Moira
Joined Feb 2006
Spent some times putting a proper section on this model, and trying to smooth the fuz out.
SD8020 on the Fin
Choice fo sd8020 or RK40 on the stab
and at the moment RK40 on the wing
Old Apr 26, 2012, 04:22 AM
Leicestershire
Joined Sep 2006
Why would you consider a cambered section for the stab, Will? I would imagine you are better off with a symmetrical unit, or your elevator trim will change dramatically with speed.
Z
Zimodile is offline Find More Posts by Zimodile
Old Apr 26, 2012, 04:51 AM
timbuck's Avatar
Joined Aug 2008
Yes ?.
Symmetrical.
HT14 is a very popular tail foil.
Old Apr 26, 2012, 01:26 PM
wdeighton's Avatar
Moira
Joined Feb 2006
I still have a lot to learn about wing sections don't I.
The main reason for the rk40 on the stab was because I had it to hand after putting it on the main wing.
last night I put the SD8020 on because I thought that was more realistic.
I have down loaded the HT14 and will have a look at it.
I am still hoping to use a DP section on the wing..
Old Apr 26, 2012, 02:11 PM
Leicestershire
Joined Sep 2006
It's not necessarily a no no. There were some pylon racers which used a very slightly inversely cambered section on the stab - arguably a lower drag method of achieving decalage. But pylon racers have a pretty good idea of the speed range they will be operating in at full bore, due to knowledge of the class/ motor performance etc. DS we don't really have an optimal speed range in mind - we just want maximum! So to have a cambered section on the stab isn't necessarily a no-no, just that it focusses the design to be optimal within a speed range.
Z
Old May 01, 2012, 03:47 PM
wdeighton's Avatar
Moira
Joined Feb 2006
bit of an update
I have a model that although it doesn't have the final section, the shapes are correct.
So I have been putting them into a CFD package to "Blow some air" over the model. But what a mission that is. There is a lot of learning going on. Loads of time on you tube watching videos. Just hope I can get there in the end, as its taking valuable design/ build / fix time.
Will
Old May 01, 2012, 04:49 PM
timbuck's Avatar
Joined Aug 2008
Sounds great will.
Evolution is a wonderful thing.
Old May 01, 2012, 04:55 PM
wdeighton's Avatar
Moira
Joined Feb 2006
What I managed to do.
What does it mean, that's where the learning comes in.
Will.
Old May 03, 2012, 02:29 PM
wdeighton's Avatar
Moira
Joined Feb 2006
Last night was one of those downer days. Just loads going wrong.
The high-lights
1)After days trying to fix my D80 wing, and thinking it was nearly done, I managed to rip what was obviously only hanging on by a thread, aileron near off (From tip to horn) I had tried to repaired the wiper but the resin was old and didn't cure, so I was trying to remove it with a dreml type brass brush, and that was enough.
2) After spending hours trying to analyse another model, I saved and restarted my machine, only to the the file not work when I re loaded.
3) After starting work on a new design, again another couple of hours, "OK to Terminate" and that is all you can do, press OK and watch your work slip away.
Hopefully today will be better. But allot of catching up to do.
Old May 03, 2012, 04:38 PM
Leicestershire
Joined Sep 2006
I.T! bang head!
Question StevensAero - G480 V2 (Re-Groove) jwoz Electric Plane Talk 11 Sep 16, 2012 09:47 PM
Sold SA G480 Re-Groove V2 pdietrich Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2012 04:18 PM
Discussion Hoy comienzo la armada de mi F22, algun tip? Agrego fotos! juanjo2 Mexico 32 Jan 02, 2008 01:16 AM
Sold compaq armada 1573dm laptop scooterr50 Non R/C Items (FS/W) 0 Oct 10, 2007 05:59 PM
Sold Compaq Armada M700 Laptop sameershah Non R/C Items (FS/W) 6 Dec 21, 2006 12:21 AM
