Old Aug 31, 2014, 10:36 PM
United States, FL, Lady Lake
Joined Oct 2013
Originally Posted by melsailsnorth View Post
Side launch, about 60% throttle (heavy Phantom with 17,000 mah 3s aboard). I aim for just above the horizon and she will fly-off without any fall or nose-down. I know a lot of people do the overhead toss with throttle but I'm afraid of whacking my fingers...
I kept watching that over and over.... How effortlessly your technique looked... Like a pro golfer effortlessly swung at the ball...
Modglock20 is offline Find More Posts by Modglock20
Old Aug 31, 2014, 10:41 PM
Joined Oct 2013
Originally Posted by FabFlight View Post
I do sidearm launch with elevons up about 4 mm with full power applied before. A gentle push toward the horizon, not really up by much. I have the stock motor on 3S and a 10x6 folding prop.
Looks like an effortless push as well... I've seen people throwing frisbees harder than that. Nice!
Old Aug 31, 2014, 10:56 PM
Canada, ON, Ottawa
Joined Aug 2013
I just toss it overhand at about a 45 angle at full power and get my hand on the stick to adjust as it climbs out... Neck strap for the x-mitter helps a lot..
Kodama is offline Find More Posts by Kodama
Old Sep 01, 2014, 02:20 AM
Preserve our right to FPV !!!!
melsailsnorth's Avatar
United States, CA, Chico
Joined Dec 2010
Originally Posted by Len02013 View Post
Nicework Mel i reckon you'll overtake my range soon.
I think i need new batterys
Actually anyone know of a good spot to get li-ion batteries?
Hey, thanks Len! It's been a fun time slowly building-up the mileage and sure is nice when everything comes together (as you know)!
I really want to give the Panasonic's a try but need to talk more with you or Chris to get a better idea of what to expect from them. Till then, I'm using Zippy transmitter packs which are a nice weight savings as compared to regular lipos but not quite on-par with the 18650's. I did my calcs after the flight and am definitely good for about 45 miles but anything beyond that will have to wait till I make some new packs myself. Ah well... slow but sure... You'll probably better your PB before I even get close
Mel
melsailsnorth is online now Find More Posts by melsailsnorth
Old Yesterday, 01:26 AM
Joined Dec 2010
Thanks Modglock! In reality, I can't take the credit, though.... The Phantom really makes it look easy! I won't name names but I have a few other big FPV wings that are just about impossible for me to get up in the air unless I launch from a big hill
Old Yesterday, 10:50 PM
Joined Nov 2012
Originally Posted by ABLomas View Post
After (ab)using two phantoms (last one with video and stuff here: http://www.rcgroups.com/forums/showp...postcount=3646), i decided to take third. Purchased v2 kit and put electronics and stuff as tested and working on earlier models. Fixed many issues i had earlier...
Sooo... Now:
- even more space for batts (16Ah 4S fits easily, that's ~20Ah in 3S batts)
- the same power setup (SK3 1200kV/10x5" graupner slowfly/simonk trust45A) - works very well (slightly more than 1KW output and very efficient)
- slightly lower weight (less stuff, less spars, but even lower strength, so Vne is less than 120km/h, need to be carefull)
- non-removable wings, everything soldered if possible - max reliability, max component separation - minimum noise onboard, minimum flexy parts.
I still don't think if i go high (my previous record is 5km altitude), if yes - plane needs many improvements. For now... Cruising around in 20km radius ;-)
Few pics:
- remains from older plane, salvaged from fields...
...now even better cutout for battz (+ few millimeters to each side)
Top side:
LED's hidden in foam. Turnstile with balun going top:
WOW... and I thought I crashed my phantom good. I'm impressed. Have you tried a laminated EPP wing like the juggernaut or something from CTH? They are much tougher.
benjahmon is offline Find More Posts by benjahmon
Old Today, 01:13 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
I do not need strong wing - need it to be strong and easily serviceable.
Going straight down at 150km/h is a mistake which should be avoided...
ABLomas is online now Find More Posts by ABLomas
New Product NEW flying wings from HObbyking - good for FPV ? i3dm FPV Talk 15 Apr 11, 2014 08:08 PM
Discussion Starting FPV with a flying wing? JYVAI UAV - Unmanned Aerial Vehicles 3 Mar 23, 2014 09:49 PM
Discussion The Fury Flyer- 54" Scratch build FPV Flying Wing Bixler13 FPV Talk 7 Mar 10, 2013 11:00 PM
Help! As3x and flying wing airplanes Jyester Scratchbuilt Indoor and Micro Models 17 Jan 22, 2013 08:29 PM
Discussion HobbyKing - Fox 2.32m EPO Glider for FPV Cralis FPV Talk 19 Sep 14, 2011 03:24 AM
