Old Oct 17, 2014, 10:28 PM
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
Originally Posted by Jezzejamez View Post
Anyone have a doppler worth anything ?
I'm wondering what others are getting on the doppler...
Here is my sunracer v4 after a month of burning motors and trying to lay everything inside so it will fit... Mental note :bring shoe horn to flight field :
Sunracer v4 typhoon 2w20: http://youtu.be/8DS68iK0Gl4
Hey Jezze!
Your 2W-20 sounds rather high-pitched! I have the same motor running in a Reverb (Mini Hawk) and it definitely does not sound that high running on 3S. The 2W-20 is only rated for 3S and not 4S so I'm guessing you're running a smaller prop than a 4.75 x 4.75.
May I ask what your setup is???
I see you're in Michigan. I was born in Windsor, Ontario, Canada (right across the river from Detroit).
Cheers!
Jabberwocky
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Oct 18, 2014, 12:09 AM
Jezzejamez's Avatar
United States, MI, Commerce Charter Township
Joined Oct 2013
Originally Posted by Jabberwocky_ View Post
Hey Jezze!
Cheers!
Jabberwocky
I'm currently using a 4.7x4.7, yes I'm using 4s I've been running this motor on 4s for over a yr. Before it was in a 4s EDF also. I'm considering trying a gm 4.75x4.75.
As you can see I give it a good amount of cool down before I land.
Jezzejamez is online now Find More Posts by Jezzejamez
Old Oct 18, 2014, 04:06 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
that 2w-20 will get to hot on 4s,,, will it hold? maybee, but not all the way.. I have been running 2w-20 on 4s few times with 4.7x4.7 props,,, to much for the motor,,, if you have really good cooling meaning full airstream threw motor( hole in spinner),, maybee it can take it..
My escape pylon with same setup did go 285km/h , so I guess you see same numbers on your SR 4..
I have same setup now on my HET comet, few burstes only, but the motor is to hot to touch when landed, hehe... I can allready guess it is going bad...
sebbe is online now Find More Posts by sebbe
Old Oct 18, 2014, 03:42 PM
Jezzejamez's Avatar
Joined Oct 2013
Sebbe,
I have all the cooling holes cut out as you no with the equipment in the fuse there's not a ton of cooling. It does get warm but here in Michigan it's a cold 50*F so this is helping me out. If my Sr v4 is doing 180mph I'm cool with it.
Thanks for the heads up..
Old Oct 18, 2014, 09:37 PM
Registered RC NUT!
The Snake's Avatar
United States, CA, Lomita
Joined Jun 2002
It seams fine to me Jezze, the GM folder is nice to save props from being broken!
The Nue or Mega should have it rock on 4S i did 5x5 on 4S, 4.7x4.7 on 5S and a 4.1x.4.1. on 6S (with the Mega)
Victor
The Snake is online now Find More Posts by The Snake
Old Oct 18, 2014, 09:54 PM
Jezzejamez's Avatar
Joined Oct 2013
Victor
Victor, thanks
Which mega are you using? I'm definitely a Mega man. I got a buddy selling a 16/25/1.5 which I'm really considering getting. I want to get into the 200mph club..
Old Oct 18, 2014, 11:03 PM
Registered RC NUT!
The Snake's Avatar
Joined Jun 2002
Mega madness
The Mega 16/25/2 F5D green but not sure if it will break 200mph but try a 5S with a 5x5 APC prop if you can get it. it can still be ordered from mega directly. The 16/25/1.5 sounds nice too, I don't know the specs of it. What's the KV?
http://www.icare-icarus.com/Mega-ACn...een_p_703.html
http://www.icare-icarus.com/Mega-ACn-162515S_p_698.html
http://www.icare-icarus.com/Mega-ACn-162515R_p_697.html
Old Oct 19, 2014, 05:48 AM
Hey Jezze!
Cheers!
Jabberwocky
I fly my SR on 4S with the even hotter 2W18. I do use a 4.1x4.1 apc prop. The whole 2.3 min flight is full throttle on a 2700 65C TP pack.
Johan
snauwaertj is online now Find More Posts by snauwaertj
Old Oct 19, 2014, 09:34 AM
Jezzejamez's Avatar
Joined Oct 2013
kv 3750...
Johan
Can't believe you are stuffing the 2700 mah battery in there . How do you do it
Old Oct 19, 2014, 01:38 PM
Description:
Description:
It all fits nicely, the downside is I have to remove both the wing and nosecone to acces the battery cables.
Johan
Old Oct 21, 2014, 10:39 AM
Jezzejamez's Avatar
Joined Oct 2013
Attachment 7205131
Attachment 7205132
Johan
Nice.
My new camera gear arrived yesterday.
So better videos to come....
Old Today, 08:26 AM
Jezzejamez's Avatar
Joined Oct 2013
New camera....
I need to adjust some settings..
What chu think?
sunracer v4: http://youtu.be/ggGYAW3X-
Question SunRacer II Questions/build pics TaSaJaRa High Performance 481 Jun 20, 2014 01:39 AM
New Product New Sunracer V3 n-2-stuff High Performance 6 Aug 19, 2010 10:58 PM
Poll Build Off III: What to build??? W@CC0 Scale Kit/Scratch Built 17 Sep 11, 2008 07:51 AM
Sunracer Build Questions nrthwing High Performance 8 Nov 27, 2005 06:56 AM
Sunracer build questions jimlang High Performance 4 Oct 21, 2005 02:22 PM
