Old Dec 09, 2013, 04:11 PM
Robert Pulse's Avatar
Davenport, Iowa
Joined Apr 2007
Question
blue wonder 1500 kv outrunners
Anyone ever use these in a boat? Do you think they will run an inch and a half 3 blade prop similar to what is used for springers without smoking?
The only reason I ask Is I have two of them that I was going to use in a flying sub conversion.
Bob
http://www.giantshark.co.uk/product/...utrunner-motor
Robert Pulse is offline Find More Posts by Robert Pulse
Old Dec 09, 2013, 05:08 PM
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
They will probably not be quite powerful enough, 1000 Kv 28 mm outrunners which draws 6 amps with a 40 MM prop, the extra RPM from the 1500 Kv will most likely push the amps to over the 9 amp rating of those motors. A smaller 1 inch prop will be OK I reckon.
Nick
nick_75au is offline Find More Posts by nick_75au
Old Dec 09, 2013, 05:45 PM
Davenport, Iowa
Joined Apr 2007
blue wonders
Nick
I was worried about that. the props in the graupner mini jets I was going to use for the flying sub, is about 3/4" and that is half the size of the inch and a half.
Thanks Nick
Old Dec 09, 2013, 09:09 PM
Tollytime's Avatar
United States, MI, Macomb
Joined Nov 2006
Thanks Nick
Why do you want such little power? Is this for a slow moving?
Tollytime is online now Find More Posts by Tollytime
Old Dec 09, 2013, 10:58 PM
Davenport, Iowa
Joined Apr 2007
Little power
LOL scale cruiser
Old Dec 10, 2013, 02:48 AM
nick_75au's Avatar
Joined Mar 2007
They should be Ok for a 3/4 inch prop
Old Dec 10, 2013, 02:32 PM
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
How about the Blue Wonder for a 10" runabout with a 3/4" prop? I have an old Scientific, mostly solid balsa runabout that was for tether running with a 1/2A engine. I would love to put an transom-mounted rudder on it and go to e-power. I have a Blue Wonder -- maybe two -- and some Li-Po's lying about that would fit her "engine compartment.". Otherwise, I would be looking at something like a brushed 6V motor.
Conversion of this boat would not be for competition, but for restoration. She has been modified to look like one of the mono-hull full sized boats that ran in the Buffalo Launch CLub regattas in the late 50's and early 60's. I would like to be able to run her around for fun with the part-time assistance from one of my three grandsons.
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Dec 10, 2013, 02:47 PM
nick_75au's Avatar
Joined Mar 2007
Hi Pete,
Should be fine, I dont think it will be anywhere near the speed of the 1/2A motor but as its for your grand kids this is probably not an issue
1/2 A from a bit of interneting 18,000-22,000 RPM and around 100 watts
Blue wonder at 7.4volts 11,000 RPM(no load) and about 60 watts if its loaded to 6-7000 RPM
I don,t think a 3/4 inch prop will load it down that much
Nick
Sold 2 "blue wonder" type motors: 23.7 grams 1700 KV 3mm shaft john-doe Aircraft - Electric - Power Systems (FS/W) 2 Dec 04, 2013 10:04 AM
Discussion replacement with more power for 1500 kV Blue wonder paulatgis Power Systems 14 Jan 07, 2011 07:17 PM
Discussion blue wonder 1500 Kv up'd to 3000 ?? doggit Electric Motor Design and Construction 1 Dec 26, 2010 06:32 PM
Found Trade my "blue wonder" 1500 kv for your "blue wonder" 1300 kv anatoly Aircraft - Electric - Power Systems (FS/W) 2 May 25, 2009 10:11 AM
Sold Tower Pro BM 2410-08 + Blue Wonder 1500 kv = $14 shipped shawn595 Aircraft - Electric - Power Systems (FS/W) 3 Nov 12, 2008 07:13 PM
