Old Jun 10, 2013, 11:02 AM
drifter_uk's Avatar
england newcastle
Joined Aug 2009
Question
Hk 450 build
Hi guys im just about to build my first cp heli after owning a honey bee cp2 a few years ago and not being able to fly it
After my recent birthday I've decided I wouldn't mind another shot at it and decided to order the
HK-450GT CCPM 3D Full Alloy Helicopter Kit (Align T-Rex Compat.)
Along with
Hobby King 401B AVCS Digital Head Lock Gyro
And the
Turnigy L2822-3700 Brushless Heli Motor (420w) with 12t pinion
Ive got loads of 2200 mah 3s lipos and a 40 amp esc to go into this build sofar but have got a list of other parts which I'm going to get which are
FMentor-3D - Flymentor 3D helicopter stabilisation System
FLYM-PPC - Flymentor Programing Box
CF-325 - 325mm Carbon Fiber Main Blades
SBEC-26V - Turnigy 5A (8-26v) SBEC for Lipo
But im stuck on what servos to go for I was thinking of tower pro mg90s for the cyclic but haven't a clue about the tail soo what would you guys recommend for the tail or both something cheap but decent
Thanks in advance and look forward to seeing your advice
Les
drifter_uk is offline Find More Posts by drifter_uk
Old Jun 10, 2013, 11:51 PM
Joined Mar 2012
for tail you can go with a fitec 9257 or you can go with hobbyking 732
volumax is online now Find More Posts by volumax
Old Jun 11, 2013, 03:56 AM
drifter_uk's Avatar
england newcastle
Joined Aug 2009
Thanks for the reply I've decided on the corona 939 for the cyclic and the 929 digital for the tail so hope these will be spot on
Just put my order in to hobbyking
Les
Old Jul 18, 2013, 02:07 PM
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
have you received your HK 450 kit yet? I was thinking about ordering one myself but had a couple of concerns about have to mod the tail boom to get rotor housing to fit
TcCobra13 is offline Find More Posts by TcCobra13
Latest blog entry: ESKY D700 3G fix
Old Jul 19, 2013, 01:30 AM
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
What issue are you talking about?
ASTREA1 is offline Find More Posts by ASTREA1
Old Jul 19, 2013, 09:00 AM
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
what i have heard about having to cut some of the tail boom to make the the rotor housing to fit,screws being too soft and rounding them off,missing parts and swash plate not moving right and sticking.just wondering if these issues have been fixed or did people just get unlucky and got damaged helis.
Old Jul 19, 2013, 10:42 AM
FPV Noob KD0VMK
United States, MO, Platte City
Joined Jun 2012
I had none of those problems with my HK450.
I think it's mostly just luck of the draw. With every HK450 kit, I think you can count on replacing 2 parts due to bad manufacturing. You won't know what they are until you put the kit together. For me, it was the main rotor shaft (it was bent when new), and the rotor head block which was too loose and wobbled all the time (even after I squeezed it down with pliers).
They certainly have their issues, but for the price of an HK450 kit, you can afford to replace a couple of parts to make it fly, and still have a bunch of money left over.
As for the screws, I suggest having a 1.5mm hex and a 1/16" hex. The 1/16" is just slightly larger for those screws heads that are a little too big to begin with. I haven't noticed they are any softer than any other small screws.
Chubbs is offline Find More Posts by Chubbs
Old Jul 19, 2013, 11:45 AM
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
ok thanks for the info
Old Sep 17, 2013, 12:33 PM
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
i'm finally starting my build thought i had the right sized crew drive for the job but it too small what size do i need to get?
Old Sep 19, 2013, 03:44 AM
Joined Sep 2013
I believe its a 2mm hex. Align have great sets pretty cheap to.
Ive built an hk450 gt and hkv2 and both been great kits with no mods needed. Yes the occasional part needs to be changed to align, I found the main gears were always warped and the tail drive gear was warped also. Other than that they flew for donks, crash and repair. Great helis for getting into the hobby.
Diggiz is online now Find More Posts by Diggiz
Old Sep 19, 2013, 10:38 AM
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
do you know what size the phillips heads are?
Old Sep 25, 2013, 08:38 AM
Joined Aug 2012
I had no problems or missing parts with mine either. In fact, for the price it's unbeatable. I'm going to order another one. The Tarot kit is supposed to be a little better but it also costs almost twice as much.
Pa flyer is offline Find More Posts by Pa flyer
Old Sep 27, 2013, 04:15 AM
Joined Sep 2013
I also have the Tarot 450 pro kit which compared to HK, Well they dont compare. Tarot was a very nice kit. But end of the day you get what you pay for. I had 2 HK 450 which did me well, and for my first heli was great. But moving on and experience you notice the difference in a good quality heli.
If I started over again I would still buy an HK, was cheap and with the turnigy 9x cost me $150. Great deal to get in the heli hobby.
Old Oct 12, 2013, 05:24 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
I got the HK 450Pro V2 FBL (torque tube) start of the year and been flying it a lot. This was also my first 'proper' heli after also failing miserably with a Honeybee years ago.
I was pleasantly surprised as to how easy the 450 was compared to the HoneyBee. To be more accurate 'easy' is maybe the wrong word because a CC heli is never 'easy' to master, but at least it's possible. Other than a few mechanical problems I've not really had a serious crash. But i have had a lot of mechanicals. The HK stuff wears out and breaks real quick and some of their servos just aren't up to it especially on the tail, I burned a couple before swapping to a genuine Align servo, no problems since.
Little by little I've upgraded my 450 to genuine Align components, only the frames, bearing blocks and tail boom are original HK!
If I had to do it again knowing what I do now, I'd have just got a genuine Align kit, but there again if I had to pay that money out in one hit back then I'd probably never have bought a heli in the first place. At least the bargain basement HK price got me into it.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Discussion Hk 450 GT PRO build advice? sebsmash Mini Helis 132 Nov 20, 2011 02:15 PM
Question HK 450 build question Dowquest Mini Helis 7 Feb 19, 2011 01:38 PM
Discussion HK-450 build questions MikeSt Mini Helis 30 Apr 05, 2010 04:58 PM
