Old Mar 06, 2012, 11:23 AM
PLANES!
Canada, ON, Guelph
Joined Oct 2011
Question
printing on foam
Does anyone know if its possible to print on foam with an lazer printer. what kind of foam? I hab some kind of unmodded HP office printer. help!
flyguy99 is offline Find More Posts by flyguy99
Old Mar 06, 2012, 09:43 PM
Build 'em break 'em fix 'em
chinaclipper63's Avatar
Joined Oct 2009
Hi Flyguy.
Search is your friend!
Try this link
http://www.rcgroups.com/forums/showthread.php?t=1308317
chinaclipper63 is offline Find More Posts by chinaclipper63
Old Mar 07, 2012, 12:36 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Be aware the OP question was about LASER printing. Most of the "print on foam" stuff I have seen is using Inkjet.
I would think twice about putting any kind of foam through a laser printer which uses a fairly high heat to fuse the toner to the paper. Might work with some EPP or Depron foams but you might just end up with a Laser Non-printer full of goo.
Be specific in your search and make sure any advice is explicit about using a laser.
I have successfully laser printed on to tissue and that works well if you can keep the wrinkles out.
Try this link
jj604 is online now Find More Posts by jj604
Old Mar 07, 2012, 07:55 AM
PLANES!
Canada, ON, Guelph
Joined Oct 2011
hey, thanks guys, but can you waterslide decal paper on a laser printer?
Old Mar 07, 2012, 08:41 AM
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
google: laser print waterslide.
first hit is http://www.decalpaper.com
Come on... TRY google... its free.
methuso is offline Find More Posts by methuso
Help! Any success printing on foam? Turbopropdrive Scratchbuilt Indoor and Micro Models 8 Mar 02, 2012 07:39 AM
Discussion printing of thin foam chem teacher2 Scratchbuilt Indoor and Micro Models 11 Feb 20, 2012 11:41 AM
Help! Help!! Need to find a horizontal feed printer for foam printing! Turbopropdrive Scratchbuilt Indoor and Micro Models 10 Feb 15, 2012 10:10 PM
Discussion Printing on foam Tanis Scratchbuilt Indoor and Micro Models 158 May 21, 2010 01:32 PM
Direct Inkjet Printing on Sheet Foam Gilley Foamies (Kits) 55 Apr 04, 2010 09:34 PM
