Old Dec 14, 2014, 08:26 PM
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
Question
pulsejet models??
Just picked up a HK PJ and wondering if you guys know of a decent model kit or ARF for this motor, thanx
lectroglide is offline Find More Posts by lectroglide
Old Dec 17, 2014, 07:01 AM
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Check out you tube. There are some nice runing examples there.
You need to make some mods, add kline regulator and make your own presure tank to make it run reliaable. ( all read in the description of videos)
Planes watch on viedo: Multiplex prop pusher jets, extreme flight delta wing arf modified.
From the above think that probably balsa usa force one, and bte delta wing could work.
Cheers
Juan
juanjulian is offline Find More Posts by juanjulian
Old Dec 17, 2014, 08:43 AM
United States, AK, Wasilla
Joined Nov 2001
Cheers
Juan
To make it run reliable on an RC airplane you will have to go to Methanol to make use of the Cline regulator. That does require a few mods to the flowjector.
hobbyboy is online now Find More Posts by hobbyboy
Old Dec 17, 2014, 05:43 PM
United Kingdom, England, Southampton
Joined Oct 2013
You'll have some fun. No throttle, they are either going or stopped. Some claim to be throttleable. It's a lie.
Wear good earplugs. I suggest you buy earplugs for everyone within about three miles too.
Don't run it too long stationary on the ground or it will melt. Stop it or fly it before it glows bright orange and you should be ok.
Here's a good one On a VERY remote Scottish island. His day job is flying a 747
RC Twin Pulse Jet (2 min 56 sec)
Mark Powell is offline Find More Posts by Mark Powell
Old Dec 17, 2014, 06:46 PM
Joined Nov 2001
https://www.youtube.com/watch?v=1e-Ar7gb4tQ
I have a pulse jet that goes from 15 to 18 pounds at idle to 50 pounds using a throttle, no lie....... :-) Cyclone 50 by Bob Maddox. Also, have a valveless on propane that goes from about 3 pounds to 10 pounds by varying the propane flow. The small ones are very hard to do that with, but bigger ones are no problem.
Old Dec 17, 2014, 10:10 PM
Joined Aug 2006
thanx guys and BTW Im an old X U/C speed guy and have seen alotta those rockets set some records, even had a small tiger jet so their nothing new to me , anyway Looks like will need a twin tail model so what would you suggest?
Old Dec 17, 2014, 10:51 PM
Joined Nov 2001
Funjet!
Old Dec 17, 2014, 10:55 PM
Joined Nov 2001
Hobbyking pulse jet with new fuel system (cline and pressurized) (0 min 36 sec)
Old Yesterday, 01:06 AM
Joined Aug 2006
Originally Posted by hobbyboy View Post
very good, so how and where did ya rig up a pressure tap, or is their one? would also like to see some pix of the dyna
on your funjet
Old Yesterday, 02:25 AM
Joined Nov 2001
That's not mine. You will not need a tap but a bladder set up.
Start about here in this thread. http://www.rcgroups.com/forums/showt...se+jet&page=41
Old Yesterday, 07:45 AM
Joined Oct 2013
I didn't know that. I have had several over the years starting with the original Dynajet and including a tiny OS one. Only ever used for control line. None of them were throttleable.
Steve Rickett, shown in the video I posted, used Italian ones. They were surprisingly inexpensive considering the probably low production numbers, about 300 Euros each (from memory). No regulator or pump, they just sucked fuel though the venturi, as the earlier ones all do. Worked fine, though his carbon home-made tanks are close to the venturi. Maybe using a pump is the path to a throttle?
Here in the UK it is near-impossible to find a place to fly them now because of the noise and because our model flying body's third-party insurance won't cover them. That's silly as they are no more powerful than the average turbine, which they do cover (without any AMA type waiver). They are a bit 'nannyish' so likely told the insurer to exclude them because of the noise.
Old Yesterday, 11:28 PM
Joined Nov 2001
Mark,
Yes, I didn't believe it either as everything I read said it can't be done, or it is really very difficult. I think the key is the fuel has to be injected after the reed valves for liquid fueled engines.
Yes, they make noise, that is one of the great things about Alaska and open land :-)
Discussion North American F-86 Pulsejet kit from the 1950's. locktite401 Vintage & Old-Timer Designs 8 Apr 03, 2014 08:52 PM
Discussion Video flight with PulseJet in the Night!! 2M86 Fuel Jet Talk 4 Sep 04, 2007 07:24 PM
For Sale 1950's F94C 215mph Control Line Pulsejet w/Engine SR71AK Aircraft - Fuel - Jets (FS/W) 0 Jul 21, 2006 02:23 AM
I'm building a pulsejet... KMKAZE Life, The Universe, and Politics 23 Aug 28, 2002 06:49 AM
"true" off topic... how loud is a pulsejet in dB? e-sailpilot86 Life, The Universe, and Politics 18 Sep 11, 2001 12:12 PM
