Old Nov 30, 2014, 07:36 PM
United States, FL, Coconut Creek
Joined Sep 2013
Question
Thrust Vectoring Servo Question
If I have a motor with a 10in prop putting out 2lb of thrust, what servo should I use?
dereelmatts is offline Find More Posts by dereelmatts
Old Nov 30, 2014, 09:25 PM
Jarhead
Joined Aug 2011
On the Hyperion Enigma, Lots of folks were using HS-65MG. Anything in that range with metal gears should be fine. If you don't want to spend the money on Hitec, look at the Emax ES08MAII. They're ~$5 each. If you prefer digital, look at the ES08MD for $6.50.
wheelbarrowjack is offline Find More Posts by wheelbarrowjack
For Sale 6x Freewing f-16 thrust vectoring servos 2low Aircraft - General - Radio Equipment (FS/W) 0 Nov 21, 2014 05:52 AM
Question Question regarding vector thrust setup using DX 18 Bzzymatt Electric Ducted Fan Jet Talk 1 May 02, 2014 03:56 PM
Discussion Question regarding vector thrust setup Bzzymatt Electric Plane Talk 0 May 01, 2014 08:21 AM
Discussion Tri with 2 thrust vector servos Ooze Scratchbuilt Multirotors 1 Mar 24, 2014 05:56 AM
For Sale NIB Exceed Rc 90mm Blue Angel Kit W/Retracts/thrust Vectoring/Servos Forrest Gump 23 Aircraft - Electric - Jets (FS/W) 2 Oct 16, 2013 01:27 AM
