Old Oct 08, 2014, 10:33 AM
Canada, MB, Winnipeg
Joined Mar 2014
Build a Run Motor tester.
Can anyone point me to a DIY build for a unit that will run the motor and ESC without RXer?
N.
NosmoKing is offline Find More Posts by NosmoKing
Old Oct 08, 2014, 10:39 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Do a search for "servo tester".
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Oct 08, 2014, 12:54 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
www.rcgroups.com/forums/search.php?titleonly=1&query=diy+servo+tester
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 08, 2014, 04:01 PM
Joined Mar 2014
Thanks, but I basically use Picmicro's as a processor, if I new the required signal requirements etc I could probably write the code, I had assumed one may be out there that used standard logic instead of processing power.
I am guessing it is just a PWM signal?
N.
Old Oct 08, 2014, 04:39 PM
yank and bank!!
Joined May 2013
A standard servo PWM signal should work fine.
failboat is online now Find More Posts by failboat
Old Oct 08, 2014, 05:19 PM
Joined Feb 2001
Search for somehing like 'servo signal' or 'servo pwm' etc.
An analog design using a 555
www.drivecalc.de
-> Servo Driver eliminating the need for a receiver during motor measurement
Vriendelijke groeten Ron
Old Oct 08, 2014, 05:24 PM
Staffs, UK
Joined Nov 2003
If you search in the DIY Electronics forum you'll find plenty of information.
Steve
slipstick is offline Find More Posts by slipstick
Old Oct 08, 2014, 06:56 PM
Joined Mar 2014
As a matter of fact I built virtually the same circuit to simulate a Pic PWM output signal some time ago, I will have to compare it.
N.
Idea Help Me Build A Servo Tester Or Struggling To Help My Fellow Modeler. My Path Fwd Murocflyer DIY Electronics 22 Jul 20, 2014 09:53 PM
Discussion Servo Motor Tester for HDD Motor? Alchemistake DIY Electronics 1 Jun 21, 2014 06:55 PM
Help! Motors don't run (first build problem) Galaktions Multirotor Talk 0 Apr 04, 2014 02:08 PM
Discussion Looing for beta-testers for a build site rikonor Scratchbuilt Multirotors 3 Dec 05, 2013 02:53 AM
Discussion Running ESC w/Reverse using Servo Tester nickr917 DIY Electronics 5 Apr 04, 2011 08:44 AM
