Old Jan 29, 2016, 11:52 AM
doublestroken is offline
Find More Posts by doublestroken
doublestroken's Avatar
United States, MN, Isanti
Joined Dec 2013
Question
speed 280 equivalent motor?
Can someone tell me if a speed 280 is equivalent to a e flite 280 brushless on 3 cells? For a Herr mini sport. I would build with 4 channel and 3.5 g servos so it might be a bit more weight than the specs noted.
doublestroken is offline Find More Posts by doublestroken
Old Jan 29, 2016, 12:35 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
Don't know about the equivalence but that motor: http://www.e-fliterc.com/Products/De...rodID=EFLM1140 will give you all the power you need on 3s. About 88.8 watts.
So, 127-178 watts/lb for the 0.5-0.7 lb AUW range.
cmdl is online now Find More Posts by cmdl
Old Jan 29, 2016, 01:21 PM
Joined Dec 2013
thanks, I'm still plenty green on current elecritic power systems. I thought the speed 280 might be a dated brushed direct drive motor.
I have a e flite edge 540 qq that would be the donor for the electronics and power system. That RTF with 450mAh was 8 oz.
Old Jan 29, 2016, 01:42 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I found a thread if it helps --
Tom Herr Mini Sport
Ray.
eflightray is offline Find More Posts by eflightray
Old Jan 29, 2016, 05:10 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
The Graupner Speed 280 has a Kv of 2333 so something in that range would would work.
That's exactly what it is.
mw
Mark Wood is offline Find More Posts by Mark Wood
Discussion ARRIS X-Speed 280 & Storm 280 flyingheli Multirotor Talk 2 Jan 12, 2016 03:54 AM
Found Apprentice BL15 Motor or Equiv MNEman Aircraft - Electric - Power Systems (FS/W) 2 Mar 23, 2015 11:43 PM
Found Looking for a AS2216-8 1250 motor or Equiv StevenFox950 Aircraft - Electric - Power Systems (FS/W) 1 Sep 20, 2014 06:02 AM
Wanted Graupner Speed 280 Motor with ESC llamame1950 Aircraft - Electric - Power Systems (FS/W) 3 Jul 27, 2014 07:06 PM
Does 280 speed motor + 8 cell nicad= burnout ? Feodosia Flyer Electric Plane Talk 7 May 29, 2001 09:41 PM
