Old Jan 13, 2016, 12:50 AM
Patzpaint is offline
Find More Posts by Patzpaint
Steel by day,Balsa by night
Patzpaint's Avatar
Canada, BC, White Rock
Joined Sep 2014
Build Log
Peter Rake 54" Nieuport 17 Prototype
The next project being undertaken is the build of a Nieuport 17 from a Manzano Laser kit of parts. Pete was nice enough to send me the plans, and the parts drawings were sent to Charlie, who promptly cut them. I am waiting for them to arrive in the next day or two.
I have always liked the Nieuports, this 17 looks like it will be a nice model, big enough for some "real scale" details.
Anyway, awaiting the parts and then getting started.
Patzpaint is offline Find More Posts by Patzpaint
Old Jan 13, 2016, 01:37 PM
WWI_Flying_Ace is offline
Find More Posts by WWI_Flying_Ace
Round engines & two wings...
WWI_Flying_Ace's Avatar
United States, CT, Southbury
Joined Mar 2013
Watching!
WWI_Flying_Ace is offline Find More Posts by WWI_Flying_Ace
Old Jan 13, 2016, 03:32 PM
slow_flier is offline
Find More Posts by slow_flier
slow_flier's Avatar
United States, PA, Pottstown
Joined Dec 2009
Oh boy! I'm signed up
slow_flier is offline Find More Posts by slow_flier
Old Jan 13, 2016, 04:38 PM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
Nieuports always fly well, (at least mine always have!)
Martin
Martin Irvine is offline Find More Posts by Martin Irvine
Old Jan 13, 2016, 08:39 PM
4dnospolk is online now
Find More Posts by 4dnospolk
United States, CA, Vacaville
Joined Jan 2014
Looking forward to watching
4dnospolk is online now Find More Posts by 4dnospolk
Old Jan 14, 2016, 08:09 AM
bth is offline
bth
Find More Posts by bth
bth
Bjørn Terje Hansebråten
bth's Avatar
Oslo , NORWAY
Joined Nov 2004
Is it the same drawing as this 40 " , or some changes ? http://www.rcgroups.com/forums/showthread.php?t=1669275
bth is offline Find More Posts by bth
Old Jan 14, 2016, 08:37 AM
Patzpaint's Avatar
Joined Sep 2014
Is it the same?
It is probably similar in design, as all of the Peter Rake plans are in different sizes, but this is 54" span as against 40" So there are most likely a few upgrades.
Old Jan 14, 2016, 09:55 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
It is a scaled and modified version of the 1/8 scale model.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Jan 14, 2016, 11:21 PM
Patzpaint's Avatar
Joined Sep 2014
First balsa dust
Seeing as I am awaiting a message that my parts are in the depot for pickup, I thought I should start on some of the fiddly bits, like laminating some tail plane pieces.
I printed out the fin/rudder onto a sheet and EasyTacked it to some 1/4" foam board and cut out the shape required.
The same was done for the elevators. I am only laminating the elevator bows, as the sharp corners on the stab appeared to break my strips on first try, so I have opted to cut and splice those 2 corners.
I selected the softest 1/16" sheet I could find and stripped off about 12 pieces X 3/16" wide.
The rudder needs 4 strips X 19" long, you could get away with 18" strips if you are careful!
The elevators need 6 strips X 15" long each.
I have always used a hot water soaking to soften up the strips. The aliphatic glue is then laid in between the strips and they are bent/pulled around the formers and clamped with blocks wrapped in tape.
Just need to wait till morning and they will be ready to assemble.
Old Jan 14, 2016, 11:56 PM
Paul Susbauer is online now
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
So, by parts, are you using laser parts on this one?
Looking forward to seeing how this one turns out. I've never had a Nieuport, though love the looks of them. I almost threw down on one of the small laser cut Guillow's N17's tonight...
Paul Susbauer is online now Find More Posts by Paul Susbauer
Old Jan 15, 2016, 12:13 AM
Patzpaint's Avatar
Joined Sep 2014
Parts
Yes, I decided that I might as well try a laser cut semikit from Manzano Laser.
Pete sent the parts drawing to Charlie and he has cut and shipped the parts.
I have not ever assembled a laser cut model airplane, so this is a first for me.
I just cut and assembled the fixed horizontal stab, but it needs 2 cut parts added.
Old Jan 15, 2016, 09:46 AM
Patzpaint's Avatar
Joined Sep 2014
First look
The horizontal stab is dry and sanded.
The laminated parts have been pulled and trimmed. I will let them dry today while I do other things, like go to the US and pickup my laser cut bits.
Should be an exciting weekend, although the weather is not cooperating with me and allowing some test/ maiden flights to be undertaken.
Old Jan 15, 2016, 02:43 PM
Patzpaint's Avatar
Joined Sep 2014
Parts are here
The laser pkg arrived. Thanks Charlie for the prompt service.
I am having trouble finding the bass for the spars. Going to try a couple more possible locals later today.
Pete, is this a good candidate for Silkspan? Found a good supply today, and they even had dope. I noticed that they had 2 grades, one was GM the other was SGM I think. Looks like the GM is the lighter of the 2.
Anyway your thoughts are appreciated. I am sure there are lots of tutorials around on using it.
Old Jan 16, 2016, 05:35 AM
Norfolk, England
Joined Sep 2001
Define Silkspan. The only Silkspan I've ever used was the tissue supplied in Guillow rubber power kits. This model is definitely too big for that.
Pete
Old Jan 16, 2016, 10:15 AM
Patzpaint's Avatar
Joined Sep 2014
Thanks Pete, that's what I thought too.
Another question for you Pete, the trailing edges are all from 3/16 bass, is this correct? The plan doesn't specify material but the parts drawing does.
I will most likely pre sand them to a taper before assembly if they are correct
Build Log 40" Besson MB411 Peter Rake Prototype Wormboy Scale Kit/Scratch Built 122 Today 01:39 AM
Build Log Peter Rake - Udet Flamingo-prototype build flyingwolfmann Scratchbuilt Indoor and Micro Models 53 Mar 26, 2016 06:11 AM
Build Log Peter Rake Prototype Build: De Havilland DH6 - New Videos T_om Scale Kit/Scratch Built 252 Oct 19, 2015 02:35 PM
Build Log Peter Rake Nieuport 17 40" ws Proto. JIMA Scale Kit/Scratch Built 242 Jul 23, 2013 09:49 PM
Video Peter Rake Nieuport 17 JIMA Electric Plane Talk 1 Nov 21, 2012 09:09 PM
