Old Jan 20, 2013, 08:01 AM
HeliCopCR1 is offline
Find More Posts by HeliCopCR1
United States, NC, Wallburg
Joined Dec 2011
Build Log
Project Alpha-UAV
Ok so this is my first attempt at drawing up a Spyder Quad. I wanted something versatile and modular enough to make it easy to fix when I inevitably auger in. Also from working with some other designs in previous copters I felt like it was prudent to make access to the electronics onboard fairly simple. I designed plates that will cover and hopefully protect the gear carried in the belly of this beast. It should workout to around a 500 class spyder if the measurements correct. This is still a work in progress and lines may change as I sit and look at this thing some more contemplating exactly where each piece of gear will be placed on the airframe. I am planning to use 5/8in Aluminum arms since that thickness seems to be substantially sturdy yet still light weight. Any ideas or thoughts as this progresses would be greatly appreciated.
HeliCopCR1 is offline Find More Posts by HeliCopCR1
Old Jan 23, 2013, 10:41 PM
Joined Dec 2011
v2
OK so a little more work on the airframe I have tried to make sure that my MWC Pro v2 will fit inside. The hatches will have stand offs to provide a little more height, yet still provide protection. The small hatch will cover a Spektrum receiver while the larger will protect the MWC. I will try to run the file through solid works tomorrow and calculate the actual weight of the panels. It looks like I have the airframe down to 350mm Rotor to Rotor. The arm mounts are spaced for 5/8 square aluminum tube arms.
Question E-flite Alpha 450 as my 1st plane? andalosy Beginner Training Area (Aircraft-Electric) 13 Feb 26, 2013 05:39 PM
Help! Need help with my FPV uav project. Soren64able Engines 9 Feb 02, 2013 05:00 PM
b/l EDF unit from Alpha Mig - other projects? down_shift Electric Ducted Fan Jet Talk 0 Jul 24, 2005 09:04 AM
Help in Project UAV rc helicopter venividivici Electric Heli Talk 11 Jul 08, 2003 07:45 PM
Project Cyclops RPV - UAV stangboy_gt Electric Plane Talk 0 Jan 01, 2003 12:02 AM
