Old Jan 08, 2015, 01:17 PM
Joined Feb 2013
New Lilliput 339DW 1280 x 800 ips dual diversity 32 channel FPV Monitor
Lilliput has just released a new model for 2015
http://www.lilliput.com/monitor/prod...ProName=339/DW
The 339DW, a successor to both the 329DW and 664W combining the best features from both monitors
Specs:
DISPLAY
Panel 7" LED backlit
Physical Resolution 1280×800
Aspect Ratio 16:9
Brightness 400cd/㎡
Contrast 800:1
Viewing Angle 178°/178°(H/V)
INPUT
Wireless 5.8GHz AV 2 (339/DW), 1 (339/W)
HDMI 1
AV 1
OUTPUT
AV 1
AUDIO
Speaker 1
POWER
Current 1300mA
Input Voltage DC 7-24V
Battery Built-in 2600mAh battery
Battery Plate V-mount / Anton Bauer mount /
F970 / QM91D / DU21 / LP-E6
Power Consumption ≤18W
ENVIRONMENT
Operating Temperature -20℃~60℃
Storage Temperature -30℃~70℃
DIMENSION
Dimension(LWD) 185×126×30 mm
Color White/Black
Weight 385g
Key features
Built-in battery & Battery level
Built-in 2600mAh battery, support up to 3-4 hours working time, and providing battery level indicator. Also supports external battery brackets for Sony, Canon, V-Mount etc
PiP Mode
339DW owns dual antennas, which can receive two different video signal channels, and technically overlayed the video signals directly on the same monitor. Also multiple Picture-in-Picture(PiP) modes can be selected.
4-hour timer & alert indicator
Creatively integrated timer function to control the flight time and avoid of flight accident when operating the UAV. Timer supports up to 4-hour countdown, and it will alert when 1 minute left.
Wireless signal sensitivity indicator
Real-time display the 5.8GHz wireless signal sensitivity of main image. It's more convenient for users to monitor the signal status of UAV.
Looks like the best FPV monitor in the market at the moment with better specs than the popular Black Pearl.
Pros over Black Pearl
Better and brighter screen panel
1280 X 800 IPS LED vs 1024 X 768 TFT LCD
400cd/m2 vs 300cd/m2
Easily foldable sunshade
Picture in picture mode for split screen viewing from 2 different frequencies
Earphone jack
External battery support using standard DSLR/Camera batteries
Wireless signal sensitivity indicator, a first for an FPV monitor
Built in timer.
Only thing i find lacking is a built in DVR which other new models are coming out with.
norazil is offline Find More Posts by norazil
Old Jan 08, 2015, 04:00 PM
Learning to crash
United States, IN, Indianapolis
Joined May 2014
When they get it in the 15 to 19" size with the same brightness range then Ill be interested.
Tom T is online now Find More Posts by Tom T
Old Jan 27, 2015, 02:53 PM
Joined Oct 2005
I just ordered 339DW from Lilliputweb. Though I liked the screen quality of the 664w, I was disappointed with the 664's receiver. Hopefully this will be better. I also like that it has battery level and a timer. The 664w would konk out with no warning when the battery was low.
st18901 is offline Find More Posts by st18901
Old Jan 28, 2015, 05:06 AM
Joined Nov 2013
Originally Posted by st18901 View Post
I just ordered 339DW from Lilliputweb. Though I liked the screen quality of the 664w, I was disappointed with the 664's receiver. Hopefully this will be better. I also like that it has battery level and a timer. The 664w would konk out with now warning when the battery was low.
I just ordered it too - in white.
What transmitter do you use/recommend.. Boscam or Black Mamba?
jenzeee is offline Find More Posts by jenzeee
Old Jan 29, 2015, 02:48 AM
Joined Oct 2005
I'm using a fatshark 250mw tx. (I don't feel qualified to recommend anything specific yet)
I only know that fatshark is compatible with Lilliput.
It also looks like DJI will work with this monitor. (the cheat card includes channel settings for them)
I just got the monitor (in black) a couple hours ago. It's night, so I haven't had a chance to fly yet. Tomorrow, I will.
first impression - It's a nice monitor. I like the sun shade better than the 664 (which had a plastic clip thing with velcro. Has more potential for mounting. Battery meter, signal strength - great. Timer (which seems kinda useless to be honest - I don't see any way to reset it)
More tomorrow...
Old Jan 29, 2015, 02:52 PM
Joined Oct 2005
Just tested the monitor and wrote a review about it...
http://www.rcgroups.com/forums/showt...t#post30631941
Old Feb 16, 2015, 12:10 PM
Joined Feb 2015
Hello, some question.
Is the monitor Lilliput 339 equiped with 'underscan' like the lilliput 664 monitor?
Is somebody of the owners willing to mail me a user manual? I coldn't find any in the web.
MoinMoin is offline Find More Posts by MoinMoin
Old Feb 17, 2015, 06:35 AM
Joined Feb 2015
Hello again,
found the manual:
http://lilliputweb.net/lanotattachme...116_manual.pdf
Looks good to me.
Old Feb 19, 2015, 03:20 PM
Joined Oct 2005
Yes the Lilliput 339 DW has underscan in menu settings. I just tested it now to make sure that it is enabled - and it is.
Old Mar 06, 2015, 09:38 AM
Finland, Uusimaa, HKI
Joined Jan 2012
Anyone know how to reset timer?
KariY is offline Find More Posts by KariY
Old Mar 10, 2015, 11:42 PM
Joined Oct 2005
far as I can tell, you have to go into the menu'ing system to do it. I hope they do something with a firmware update or something because it's pretty useless as it is right now.
Old Mar 19, 2015, 10:30 AM
Kapoon's Avatar
Kazakhstan, Astana
Joined Jun 2014
does it work with immersionRC 600mw? I ordered two of 339/DW and now I need transmitter
Kapoon is online now Find More Posts by Kapoon
Old Mar 21, 2015, 03:18 PM
Joined Mar 2015
i am also thinking about buying that monitor - the specs looks really good. but now i have read that there are also some monitors already with PVR out. Thats interesting because my StormRacingDrone doesnt need to carry another camera then.
Any suggestions in regards to such a monitor? Sadly lilliput doesnt have one directly with PVR function.....
toxiroxi is offline Find More Posts by toxiroxi
Old Today, 08:22 PM
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
Looks like a nice little screen. Why aren't more people talking about it? Price maybe? I can only find it for 309.00usd
IH8VTEC is online now Find More Posts by IH8VTEC
For Sale Lilliput 7" 664 HDMI in IPS Slim monitor kuau FPV Equipment (FS/W) 2 Dec 29, 2014 11:25 PM
Sold Black Pearl 7 inch LCD FPV Monitor - RPSMA 32 Channel titanflyer Aircraft - Electric - Multirotor (FS/W) 0 Oct 16, 2014 12:50 PM
Sold Black Pearl 7 inch LCD FPV Monitor - RPSMA 32 Channel titanflyer FPV Equipment (FS/W) 0 Oct 16, 2014 12:43 PM
Discussion Lilliput 329/DW - 7" FPV monitor with dual receiver BoeingSWTech FPV Equipment 4 Aug 25, 2014 11:08 PM
For Sale Reduced to Clear… Gaui 500x Quad, Spektrum DX7, FPV t/x r/x, Lilliput Monitor Ray2.2 Aircraft - Electric - Multirotor (FS/W) 3 Apr 09, 2013 09:52 PM
