Old Jan 27, 2015, 03:14 AM
yorkshire UK
Joined Oct 2007
Originally Posted by erieqc View Post
I have a new X4R receiver the standard 4 channel not using sbus or anything else and I hooked up to a crack yak with digital servos and the servos went nuts and now they don't work anymore. If I hook it up to a ds821 it will work. I know the other servos are probable fried. My question is 1. why did they fry and 2. I'm bought another set of digital servos for it is there anything special I have to do with reciever so I don't fry another set.
Strange, I would check that you have not got the s.bus version by mistake but even then I would only expect one CH to be effected.
Not heard anyone else have this happen,
Supply volts worth checking for polarity and volts.
nigelsheffield is offline Find More Posts by nigelsheffield
Old Mar 10, 2015, 04:20 AM
Australia, QLD, Brisbane
Joined Nov 2010
CPPM on X4R
From the FrSky forum here:-
http://www.frsky-rc.com/BBS/viewtopi...4fa07357cdcc13
X4R CPPM output
Postby Xu@Frsky 2015-03-09 3:41
Hi, All FrSky customers, we plan to make a firmware for cppm output of X4R, how to allocate physical channel and make full use of all channels? we are looking forward to your suggestions. Please post your thoughts here, Thanks!
Here's your chance to have a say.
lexm is online now Find More Posts by lexm
Old Mar 10, 2015, 05:40 PM
Australia, SA, Adelaide
Joined Aug 2012
I looked at the thread linked to. What are S1, S2, S3, S4 referred to in several posts? My Rx don't have actual jumpers, S1 through S4 would normally refer to signal channels, but if so, how can these pins also be simultaneously used for outputs?
Is the proposal for a new receiver design with jumpers, or a firmware change for current receivers?
mpjf01 is online now Find More Posts by mpjf01
Old Mar 10, 2015, 06:16 PM
Joined Nov 2010
Jumper on channels when binding and then removed, like done when binding different modes on X8R. Not like a D4R where the jumper remains for CPPM mode.
Don't know. Ask Frsky.
Old Mar 12, 2015, 02:31 PM
jlipscomb's Avatar
Spain, CT, Reus
Joined Jan 2014
Using X8R to run Strobon switch/LED's ?
Hello everyone.
Can the X8R handle a 5vdc output on one of it's free channels to run this device?
http://www.flytron.com/led-systems/3...ipes-pack.html
Specific information on the Strobon controller and power requirements are here:
http://www.flytron.com/led-systems/2...ontroller.html
I know the X8R can output 5vdc, but what worries me is the current consumption spec:
50mA - 1A depends pattern and power level
I've done some digging on top of reading the X8R PDF, but I'm still unclear if the Rx can handle a 1A current draw. Could someone please advise? Thanks!
jlipscomb is offline Find More Posts by jlipscomb
Old Mar 12, 2015, 02:46 PM
Tomkfly's Avatar
United Kingdom, England, Birkenhead
Joined Jan 2013
Originally Posted by jlipscomb View Post
Hello everyone.
The Rx should be able to handle 1 amp depending on what the servos are pulling, but to make sure you could feed the 5volts directly to the + and - contacts on the unit from the Rx battery, so the Rx would only be handling the signal power. I do this with my Sbus as 16 servos would be too much for the RX power bus.
Tom
Tomkfly is offline Find More Posts by Tomkfly
Old Mar 12, 2015, 03:02 PM
jlipscomb's Avatar
Spain, CT, Reus
Joined Jan 2014
Tom
Hey Tom. Well the Rx in this case would be installed in a F550 hex, with Naza-M V2. hardware. So the Rx picks up it's power from the PMU which in this case warns that it's only happy with a continuous output of 3A@5V. Since the PMU is powering other components like the GPS system, I'm left feeling there may not be much headroom left over for the Rx should I pull full spec (ie, 1A).
I have considered adding a 5v, 3A BEC to supply the Strobon controller directly, and then running the signal wire to the Rx to control from my Taranis. Is that sorta what you meant?
Old Mar 12, 2015, 04:33 PM
Tomkfly's Avatar
Joined Jan 2013
You can do it that way, but you also have to connect the -ve wire to the Rx
Tom
Old Mar 13, 2015, 03:24 AM
jlipscomb's Avatar
Spain, CT, Reus
Joined Jan 2014
Tom
Ah yes. Thanks for the heads up on that.
Old Mar 24, 2015, 11:37 PM
SirEdward
blimppilot@ph's Avatar
Philippines, NCR, Pateros
Joined Apr 2004
I don't usually cross post but this might be a safety concern.
Just a heads up to everyone and a shout out to Frsky.
A fellow was having an issue with his X8R rx going on and off intermittently until he opened the case and found out that some pins were not soldered at all.
As with all other mass produced product no one knows when will you get a dud item. "Expensive" "High Quality" "Top brand" products have one way or the other suffered from QC issues and this brand is no exception.
I still very much like my Frsky goodies though.
blimppilot@ph is offline Find More Posts by blimppilot@ph
Old Yesterday, 05:39 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Don't panic unnecessarily.
I may be wrong - but I if recall correctly that is not a fault. Those pins do nothing. They have just used 3 pin headers to make a single connection.
jj604 is offline Find More Posts by jj604
Old Yesterday, 06:13 AM
SirEdward
Joined Apr 2004
Well sorry to bust you out but you are wrong. One is SBUS port and the other is RSSI... and if you are using sbus you might be in for a big surprise while in flight
Old Yesterday, 07:04 PM
ancora imparo
jj604's Avatar
Joined Jul 2005
Ah, you are correct. I should have paid more attention to which pins they were.
Sold 550 X Pro Series Combo without ESC by BLADE (BLH5595C) rmarlan Aircraft - Electric - Helis (FS/W) 1 Jan 04, 2014 05:35 PM
Sold NIB Super Tigre G .60 Series X RE nero1156 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 29, 2013 04:49 PM
Wanted Super Tigre X-Series .60 softlanding Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 19, 2013 05:34 AM
Sold ST Serie X G.45 with tuned pipe wing881 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 12, 2013 02:01 PM
For Sale T-Motor Navigator Series MN-4014 330KV x 8 dasrustler Aircraft - Electric - Multirotor (FS/W) 0 Nov 18, 2013 10:24 PM
