Old Dec 17, 2003, 06:45 AM
jimmyray's Avatar
Oxford, Alabama USA
Joined May 2001
Float plans for Slow Stick?
Anyone know of proven floats plans (bluecor?) or a source for floats for the GWS Slow Stick? My Brother lives on a lake, and would like to be able to interchange wheels and floats on his new Christmas Slow Stick.
Thanks!
jimmyray is offline Find More Posts by jimmyray
Old Dec 17, 2003, 07:20 AM
USA, GA, Villa Rica
Joined Nov 2003
http://www.foamfloats.com/
There is also an article about the SS on 25" foam floats, I will see if I can find it,
dave
qy8flyer is offline Find More Posts by qy8flyer
Old Dec 17, 2003, 07:23 AM
USA, GA, Villa Rica
Joined Nov 2003
http://www.foamfloats.com/sub/subslowst.doc
Its a word doc, and he use 23" floats , let us know how it comes out, I have been thinking about doing the same thing,
Old Dec 17, 2003, 07:44 AM
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Here is a set of I build specifically for the Slow Stick and have flown them extensively off water. They are made from the very inexpensive and widely available white insulating foam. A flat bottom version is here. Currently I am using the floats for flying off snow. I also have a design made from the foam taken from Sturdyboard(Depron) that I plan to post in the near future.
jimsp is offline Find More Posts by jimsp
Old Dec 17, 2003, 07:46 AM
Ron H's Avatar
Bishopville S.C.
Joined May 2003
jimsp designed some nice ones. See this thread. The last post has a link to revised plans.SS on floats
{I type too slow! Great work jimsp!}
Ron H is online now Find More Posts by Ron H
Old Today, 01:40 PM
Joined Nov 2005
I tried to go to www.foamfloats.com and my antivirus program says site contains malware. Any body having this problem.
DuBonnet is offline Find More Posts by DuBonnet
Old Today, 05:26 PM
USA, GA, Villa Rica
Joined Nov 2003
Dubonnet,
I cant get to that site either. I think they might not be in business anymore.
I cant say enough about JimSp original design using the single pontoon design and out riggers.
this has been the most successful and fun flying plane on the water for many of us.
there are 2 ways you can build it,
original way was to build it from 3 mm depron to create a hollow pontoon. I also used the solid method , but cutting from a single block of foam, you can get 1 inch foam at HD and 3M 77 sheets together to create a big block , then use a hotwire or bandsaw to cut the top profile , then rotate the block 90 degrees and cut the front view profile, the result will be the intersection of the two profiles and your pontoon. glass and PU or use monokote to finish
let me know if you understand , i will try to get some pics if you need
Are there any plans for a Slow Stick fuselage sgil2001 Foamies (Kits) 6 Jun 13, 2005 02:23 AM
Any plans for a SLOW STICK (FD)? bubbadice GWS (Grand Wing Servo) 1 Oct 14, 2003 03:31 PM
9.6v 800maH for Slow Stick? cousinrex Parkflyers 1 Sep 09, 2002 10:23 AM
Battery To Heavy For Slow Stick?? AL TYLER Parkflyers 6 Sep 04, 2002 01:37 PM
What size ESC for a Slow Stick? Bob Mintus Parkflyers 3 Sep 02, 2002 02:42 AM
