Old Feb 02, 2015, 06:35 PM
Flying Pitcher is offline
Find More Posts by Flying Pitcher
I'm breaking-in helis.
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
tail travel limit!!
hey guys, i read somewhere that you don't want to set the tail travel limit too much, because it may stall tailblades with too much pitch and may be less effective.....
do you go to almost mechanical limit on the travel?(as far as it can go) or do you still have room left on the ends??
also, how does it impact if you fly with lower rpm's...?
let's hear it, i'm ready to be educated!
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Feb 02, 2015, 11:38 PM
ZeniethLily is offline
Find More Posts by ZeniethLily
Ground Repeller
Singapore
Joined Jun 2014
I set it so that it doesn't bind with the edges for both my Agile 5.5 and Goblin 500, for the Chase 360 the throw is so extreme i had to limit it to about half of it so that I could keep it under control.
ZeniethLily is offline Find More Posts by ZeniethLily
Old Feb 03, 2015, 12:00 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Depends on the heli. Some I've needed to set it so I've got every fraction of a millimeter possible, a hair width from binding (The Trex). Others such as the 7HV the manual says to set it only traveling part way and i can still get the tail blades barking easily, so no need for more.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 03, 2015, 02:19 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
My experience with Align 500 and 550 is that I set it as close to the ends as I can. Never had an issue in flybarred or fbl form.
abenn is offline Find More Posts by abenn
Old Feb 03, 2015, 03:14 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
An easy question to answer in that you will probably know when you stall the tail blades.
And a difficult one to answer. The airflow is changing depending on how you fly. Peoples helicopters are different. So the maximum one can get away with, can be to much for someone else. How deep into the stall you can get away with also depends on those same things.
When you stall the blades you can get lots of noise. The drag goes way up, and the tail rotors lift drops quickly. Some high powered setups can overcome the increased drag to a point. If you go beyond that point you may lose control of the tail.
The rule of thumb is that around a max of + - 25 degree's is usually safe.
Roto Rob is offline Find More Posts by Roto Rob
Old Feb 03, 2015, 07:04 AM
spykez is offline
Find More Posts by spykez
Where's the swimming pool
spykez's Avatar
Joined Jul 2011
I've always set mine to just avoid binding and getting the vbar happy. I've been happy enough to leave this to the gyro, although what you say does indeed have theoretical merit - if you're not using the whole tailshaft, why not get more resolution for the gyro?
I myself don't know how much of the tailshaft the vbar _atually_ uses on my helis, but I've not had any tail problems, so I'm likely to continue the way I am.
spykez is offline Find More Posts by spykez
Old Feb 03, 2015, 08:09 AM
Aberdeen
Joined Mar 2006
I always get full resolution from the gyro. I do that by adjusting what hole I use on the servo arm so that the travel on the servo (as set in the FBL controller) is in the optimum range.
No point in always using every bit of travel that's mechanically available if all the last bit of travel is doing is stalling the blades.
Old Feb 03, 2015, 10:29 AM
Joined Apr 2013
o i see. well, i read somewhere that with lower rpm, blades stall quicker, so I figured since i'm flying with lower rpm, i need to limit my throws. But i don't have any blow-outs. I did when i was flying 860 headspeed using 3s, but that's another story and not very relevant i guess.
reason i'm asking is i have plenty more room for more pitch maybe i need to experiment again, but little reluctant because it works fine as it is now....25 degrees?? i read somewhere airfoil is good for 12 degrees...
Old Feb 03, 2015, 11:50 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Airfoils vary, 12 degree's is low, some are dropping by 8 degree's. Many can make 15 to 18, compared to the air flow into it. The Inflow can change things, however its hard to predict. So depends on how much risk your willing to take. If you are into less risk keep the max pitch under 18.
https://www.faa.gov/regulations_poli...a/hfh_ch02.pdf
Old Feb 03, 2015, 12:07 PM
Joined Apr 2013
aah, i see. well, if all works, then no need to adjust i guess...
i'm experimenting too much. need to fly more Boi i tell ya, there's a lot going on with the wings
Old Feb 03, 2015, 01:03 PM
2Doggs is offline
Find More Posts by 2Doggs
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
When you think of everything that's going on, it's amazing that single rotor helis fly as well as they do!
I noticed that my Forza can go up to about 42 degrees against torque, and about 39 with. Using that much will surely cause blade stall, so I may try reducing my tail limits. I normally set them just a few points off the mechanical limit to prevent the tail servo stalling. It's funny, tho, you'd think heli designers would make the tail rotor just long enough to be able to give the required pitch range in the tail rotor.
2Doggs is offline Find More Posts by 2Doggs
Old Feb 04, 2015, 01:32 AM
McKrackin is offline
Find More Posts by McKrackin
Incurable heli addict
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Can you guys explain what you mean by stalling the tail rotor?
When I hear stall,I think of the blades slowing or stopping and that just isn't possible unless it slows or stops the main rotor...90 degrees of pitch on the tail could never have any real effect on speed so you're obviously talking about something else.
As for pitch...I set mine up with everything it can get and then two clicks more.
Most tail gyros will take care of the rest.
I set my radio ATVs to 60% to get my 250 degrees per second piro rate.
McKrackin is offline Find More Posts by McKrackin
Old Feb 04, 2015, 01:36 AM
Ground Repeller
Singapore
Joined Jun 2014
For helis, it means the rotor blades are no longer able to produce any lift at that given RPM, which causes weird behaviours such as sudden uncontrolled banking or pitching (just an example not limited to) - in the case of the main rotor.
Old Feb 04, 2015, 08:01 AM
2Doggs is offline
2Doggs's Avatar
Joined Nov 2009
Make it happen!
If a car engine stalls, it stops. With an airfoil, such as a wing or rotor blade, that's not what's meant. When the angle of the airfoil to the relative airflow gets to a critical point, the air will break away from the airfoil instead of flowing smoothly around it. Drag rises, and lift reduces.
There is a way to experience this quite safely. In HH mode, a heli will often spool up with the tail all the way over to one side or the other. As it spools up, the gyro will reduce pitch in the tail rotor when it starts to generate enough force to turn the heli.
If you have enough tail rotor pitch - that is, too much pitch - the tail rotor can be stalled. You will hear an odd "mushy" sound from the tail, and the heli will take longer to get up to full rpm. At some point, even tho stalled, the tail generates enough force to turn the heli and the gyro reduces tail pitch. The mushy sound goes away, and the rotors speed up more rapidly.
Of course you can avoid all this by centring the tail rotor before spooling up, but it's an easy way to see if you have too much tail pitch.
And friends, I know this story is true - because I can make it happen every time with my Forza if I set the tail limits to the full 42 degrees of pitch!
Old Feb 04, 2015, 08:45 AM
jombo is offline
Find More Posts by jombo
AMA# 548800
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
I max mine out in both direction so they don't bind . The real trick is to set a head speed and not get drift in rate before going into HH MODE
jombo is offline Find More Posts by jombo
Question Servo speed/travel limiter LVsoaring Radios 9 Aug 09, 2014 07:57 PM
Discussion Servo physical travel limit & DX9 Dirty Dee Radios 20 Mar 05, 2014 11:24 PM
Help! Multiwii Servo Travel Limits (Endpoints), Tricopter Config. FIREotter Multirotor Electronics 3 Dec 13, 2013 01:34 PM
Discussion T-Rex: Limiting tail servo travel? bjaffee Mini Helis 0 Feb 09, 2006 05:09 PM
Limited throttle travel in our modern transmitters Top Gun Power Systems 13 Jul 11, 2001 04:26 PM
