Old Jun 03, 2014, 11:20 PM
ElkSlayer is offline
Find More Posts by ElkSlayer
United States, ID, Moscow
Joined Jan 2014
Flyzone Albatros replacement prop or fix???
So, I bought a new pinion gear for my Albatros only to find out that my prop doesn't fit tight enough to be useable. Problem is, there doesn't seem to be replacement props available in the country. Is there a way to modify the prop so it will work? Anyone else that makes a prop that will work?
Jim
ElkSlayer is offline Find More Posts by ElkSlayer
Old Jun 04, 2014, 12:00 AM
cmdl is offline
Find More Posts by cmdl
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
a little CA on the end should make it fit.
fyi, there is a dedicated Albatros thread in the Micro forum.
cmdl is offline Find More Posts by cmdl
Old Jun 04, 2014, 11:01 PM
Joined Jan 2014
thanks!
Discussion To fix or replace? Snardo Foamies (Scratchbuilt) 3 Oct 21, 2013 03:01 PM
Help! Replace Flyzone Albatros pinion gear mu2freighter Micro Ready-to-Fly 7 Jul 22, 2011 01:38 PM
Discussion Flyzone Albatros-Does it fly slower, same, or faster than the Hobbyzone Champ? newflyer100 Micro Ready-to-Fly 7 Jun 29, 2011 09:21 PM
Replace or fix bent prop shafts...... Cal Power Systems 5 Sep 01, 2004 11:06 AM
TM - Bent prop shaft or fix or replace? (m100?) dpoles Parkflyers 6 Jun 20, 2002 10:53 PM
