Old Aug 12, 2013, 09:26 PM
kidlat is offline
Find More Posts by kidlat
Joined Aug 2011
T-rex 250 Pitch Range
I couldn't get an answer from the 250 forums. What is an ideal pitch range for a 250 with a 4200KV motor and 14T pinion? Is +12 to -12 too much?
kidlat is offline Find More Posts by kidlat
Old Aug 12, 2013, 09:47 PM
FyreSG is offline
Find More Posts by FyreSG
新加坡的飞儿
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Pitch range is subjective, what's too low for me may be too high for you. Pitch range determines the responsiveness of the vertical movement. If you find that the heli is too sensitive to your throttle stick movements, reduce the pitch range.
It also depends on the moves you execute on the heli. Do you need the heli to shoot up like a rocket? You'll need more pitch range. I suspect you're new to this, so worry about that later. Start with +/- 9 degrees, and adjust according to your preference.
FyreSG is offline Find More Posts by FyreSG
Old Aug 12, 2013, 10:38 PM
kidlat is offline
Joined Aug 2011
Thanks!
Old Aug 12, 2013, 11:47 PM
joeclone is offline
Find More Posts by joeclone
joeclone's Avatar
Joined Jan 2013
This might help http://runryder.com/helicopter/galle..._manual-lo.pdf Manual recommended is 11degs but as Frye said 9-10 is a good value to start with but dun go too hi as to bog your motor or too low to need too hi a headspeed just to hover.
joeclone is offline Find More Posts by joeclone
Old Aug 13, 2013, 01:02 AM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
For my 250 size FBL (Skyartec X3V) with 4500kV motor, 14T pinion, 2S battery, I'm using a pitch range of -12 to +12 degrees. According to the manual, I can use -11 to +11
Make sure you use a digital pitch gauge to check your pitch and confirm its really what you think it is! (Using a manual gauge with bubble level I was off by about 2-3 degrees)
Once the pitch range is set, I then use my pitch curve to give me the pitch value I want.
For normal flying I use a curve that starts at -4 degrees pitch, and then goes to zero pitch at 50% throttle, then goes to 12 degrees at 100% throttle. The throttle curve with this is 0 to 100% linear.
This is a gentle setting for normal flight/beginners. If you were using a 3S battery, I would expect you would need to use lower values for the throttle curve?
Lentar is offline Find More Posts by Lentar
Sold ALIGN AP800 Digital Pitch Gauge HET80001 T-REX 250 450 500 600 700 800 helifreak592 Aircraft - Electric - Helis (FS/W) 0 Mar 31, 2013 11:00 PM
For Sale NIB T-rex 250 DFC Without 3GX Niko 182 Aircraft - Electric - Helis (FS/W) 0 Jan 04, 2013 09:28 PM
Sold Align AP800 Digital Pitch Gauge HET80001 T-REX 250 450 500 helifreak592 Aircraft - Electric - Helis (FS/W) 0 Oct 22, 2012 09:05 PM
For Sale Align AP800 Digital Pitch Gauge HET80001 T-REX 250 450 500 550 600 700 helifreak592 Aircraft - Electric - Helis (FS/W) 0 Apr 11, 2012 10:34 PM
Discussion T-Rex 600E Pitch range adjustment problem Timmskyline350gt Electric Heli Talk 0 Jul 21, 2008 10:48 PM
