Old Dec 07, 2014, 11:30 AM
californiakid is offline
Find More Posts by californiakid
mahoganyfan
californiakid's Avatar
United States, NJ, Atlantic City
Joined Nov 2010
Idea
Aluminum Hatch Strips
Hello everyone, Happy Holidays to all. I am posting a question to see what others have done to help keep the aluminum hatch strips down on the engine hatch. This is the Thunderbolt kit I finished up last winter. The problem I am having is the engine hatch strips lift up on the corners or the strip completely comes off. I have used the supplied double sided tape numerous times on the hatch strips but they keep popping up or completely come off. I used the double sided tape on my crackerbox and it held the engine hatch strips on fine. I am looking to maybe use small screws to keep them down, has anyone used the screw method? Any other ideas that I can use to make sure these hatch strips stay down on the hatch for the long term?
californiakid is offline Find More Posts by californiakid
Old Dec 07, 2014, 12:20 PM
Browndog is offline
Find More Posts by Browndog
Browndog's Avatar
United States, CT, Wethersfield
Joined Mar 2006
Try putting a little crown in them before putting them on
Browndog is offline Find More Posts by Browndog
Old Dec 07, 2014, 12:54 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
George is right. You must bend the aluminum strip so that it matches the crown of the deck. Also do not try on a waxed deck. Clean the surface with rubbing alcohol before sticking down the tape.
frankg is offline Find More Posts by frankg
Old Dec 07, 2014, 12:57 PM
heavymeasure is offline
Find More Posts by heavymeasure
United States, IL, Chicago
Joined Jul 2011
I had the same trouble. I put a crown on the strips and they now stay down.
heavymeasure is offline Find More Posts by heavymeasure
Old Dec 07, 2014, 01:27 PM
frankg is offline
Joined Dec 2004
Larry- just in case you are wondering why, the straight piece of aluminum trim will be acting like a left spring when you just tape it down without pre-bending it. That means that the adhesive on the tape will always be under tension and will pull up if not bent.
Old Dec 07, 2014, 03:20 PM
oldbilgewater is offline
Find More Posts by oldbilgewater
United States, PA, Quakertown
Joined Jan 2012
Good suggestions , above .
My solution , all aluminum that I didn't want to tack or screw down inside the boat or on BLIVET'S case ( shown ) is held on with E 6000 . Sticks to alum. well , as well as painted surfaces .without damage to paint. Far exceeds Dow / GE silicone seal for strength and grip .
Bow the alum.
Clean painted surface with alcohol , alum . with laquer thinner .
Apply E 600 to alum.
Clamp in place ( Min. 36 hrs ) Because it will be tight ,so dry time will be long .
Immediately wipe off excess .
Wait 10-15 min. and wipe (roll ) off any smudges .
It will not screw up your paint ( I know , I got plenty on my urethaned mahogany )
Just another suggestion .
E 6000 .....clear .........spout tip . At MICHAELS or JOANN FABRICS .
oldbilgewater is offline Find More Posts by oldbilgewater
Old Dec 09, 2014, 09:40 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Pins.
http://www.rcgroups.com/forums/showt...ed#post7563562
patmat2350 is offline Find More Posts by patmat2350
Old Dec 10, 2014, 11:34 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Originally Posted by patmat2350 View Post
Pins got the right look, but it will help to pre bend them.
Sharky1dk is offline Find More Posts by Sharky1dk
Wanted Great Planes Shoestring GP/EP Canopy/Hatch pdansalvish Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2014 09:59 PM
Sold Hatch Covers, AVA Pro, Supra, Sprite rev.iain Aircraft - Sailplanes (FS/W) 2 Sep 28, 2014 09:17 AM
Help! Need Battery Hatch for Flyzone Staggerwing bayou_city_boy Electric Plane Talk 0 Sep 25, 2014 07:54 PM
Discussion LED Strips (Like UH LED Strips) Dim with Throttle Bohh33 Night Flying 13 Aug 22, 2010 11:07 PM
Attaching Alfa Rotor to Aluminum Hub/motor shaft Adapter. Stripped Threads! aplphabandaid Electric Ducted Fan Jet Talk 5 Aug 02, 2009 11:54 AM
