Old Apr 24, 2013, 02:15 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Originally Posted by RCBlackSheep View Post
A hook can be made from a nail as well...
This method, no mater how you make it, allows for easy adjustments and may be made to not extend into the fuse as far as the screw method.
ozmo01 is offline Find More Posts by ozmo01
Old Apr 24, 2013, 09:53 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
If you use a machine screw (threaded) hook with a T nut, you can make it adjustable by not gluing the block into the fuse.
Instead, cut a slot in the range of movement you are looking for, then use a small sheet metal screw to secure the block through a hole ahead of the slot in the fuse. Multiple holes in the block for the sheet screw allow the hook to have multiple positions.
I think this was a JT tip, if I recall correctly.
R,
Target
target is offline Find More Posts by target
Old Apr 25, 2013, 07:11 AM
kzimmerm is offline
Find More Posts by kzimmerm
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
Montrose, NY
Joined May 2003
R,
Target
I have this type of hook in my Addiction. Simple but affective.
Kurt
kzimmerm is offline Find More Posts by kzimmerm
Hangar 9 Tow Hook TGKconnectors Non R/C Items (FS/W) 2 Jan 26, 2013 07:11 PM
For Sale Rocket City Pro-Tow Tow hook. ronrange Aircraft - Sailplanes (FS/W) 1 Jan 24, 2013 10:15 PM
Wanted Adjustable tow hook for flat bottom fuse ak79 Aircraft - Sailplanes (FS/W) 6 Jan 15, 2013 09:36 PM
Sold Airtronics Metal hook releasable tow hook gavoss Aircraft - Sailplanes (FS/W) 1 Mar 09, 2012 04:14 PM
