Old Jul 04, 2015, 02:01 PM
ccberryman is offline
Find More Posts by ccberryman
Joined Aug 2008
Have a Calypso and flown it several times. I am concerned about the wing locking screws. How do they lock the wings in place when they do not appear to come down on the wing spar?
Ccberryman@aol
ccberryman is offline Find More Posts by ccberryman
Old Jul 04, 2015, 04:16 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
There is a plastic insert in the wing that the spar goes through. The screw squeezes the plastic insert together that holds the spar in.
hendrnk is offline Find More Posts by hendrnk
Old Jul 04, 2015, 05:51 PM
Imageek2 is online now
Find More Posts by Imageek2
Bad command or file name
Imageek2's Avatar
United States, CA, Riverside
Joined Jan 2013
Ccberryman@aol
See post 765 on this thread.
http://www.rcgroups.com/forums/showp...&postcount=765
Tom
Imageek2 is online now Find More Posts by Imageek2
Old Jul 06, 2015, 07:59 AM
Nova - K is offline
Find More Posts by Nova - K
rcnova
United States, IL, West Chicago
Joined Jul 2009
cool photo in flight
Nova - K is offline Find More Posts by Nova - K
Old Jul 06, 2015, 08:33 AM
ombudsman is offline
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
Yeah, that is a nice pic.
ombudsman is offline Find More Posts by ombudsman
Old Jul 06, 2015, 01:49 PM
theo2076 is offline
Find More Posts by theo2076
United States, IN, Westfield
I'm thinking of picking up the ARF Calypso. I was hoping to use some electronics out of a totaled Kunai. Will these parts work?
4x - Hitec HS-5055MG 9g Mico Servos (Alileron/Elevation/Rudder)
2x - TowerPro 9g Mico Servos (Flaps)
ZTW Mantis 25A ESC
30mm spinner (3mm shaft)
8x7 or 8x6 folding prop
GPMA2288 1400 kV outrunner (from Kunai)
The only thing I'm really not sure on is the motor/prop/spinner combo. Thoughts?
theo2076 is offline Find More Posts by theo2076
Old Jul 06, 2015, 04:17 PM
hendrnk is offline
Joined Apr 2012
ZTW Mantis 25A ESC
Most of that will work. Except the spinner needs to be 50mm from memory. Also you will need to reverse th engine shaft.
Old Jul 06, 2015, 05:57 PM
netarc is offline
Find More Posts by netarc
netarc's Avatar
Joined Apr 2013
Calypso revival
After a couple of bad nose-in crashes couple of years ago, I'm only just now getting to reviving my Calypso. Major gorilla glue-based repairs of the front fuselage were required, and I replaced the motor with a Firepower 450 from HURC along with metal spinner. Pix below .... hopefully the additional gap between spinner and fuselage (due to longer engine) won't cause too much drag!
netarc is offline Find More Posts by netarc
Old Jul 06, 2015, 09:09 PM
NewZee is offline
Find More Posts by NewZee
Foam is my friend!!!
NewZee's Avatar
United States, NY, Depew
Joined Mar 2014
I'll bet she flies just as good as ever! nice job on the repair!! I do see the new motor is a "prop drive" with a bolted on propeller shaft? if that's the case does the motor shaft come out the back of the motor? if so you could possibly reverse the motor and connect a folding prop hub directly to the motor shaft (not the prop drive adapter shaft). This might get the prop & spinner a little closer to the nose?
I still think she will fly just fine the way it is! let us know!
NewZee is offline Find More Posts by NewZee
Old Jul 08, 2015, 03:06 PM
netarc is offline
netarc's Avatar
Joined Apr 2013
yes, the motor does have a bolted on propeller shaft, with the shaft reversible so that it can exit either side of the motor. However, I can't reverse the motor as that would have the static side at front, and I'd be unable to mount it in that orientation - is that what you mean?
Old Jul 30, 2015, 09:52 AM
leadpan is online now
Find More Posts by leadpan
leadpan's Avatar
United States, CA, Eastvale
Joined Sep 2007
Assembling the Calypso ARF last night; mounting the engine is a bear!
Everything else seems easy, however. Can't wait to maiden.
leadpan is online now Find More Posts by leadpan
Old Jul 30, 2015, 02:27 PM
MK is online now
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
In what ways? Looking at this once again due to rebate and coupon code that I have from Tower.
MK is online now Find More Posts by MK
Old Yesterday, 09:26 AM
leadpan's Avatar
Joined Sep 2007
I found mounting the motor into plastic casing difficult. Lining up the screws from inside fuselage to motor is difficult. Finally got lined up by using a long screw to hold motor then positioning motor for other screws.
Discussion Flyzone Calypso george@dream-flight Electric Sailplanes 72 Jul 06, 2015 05:56 PM
For Sale Flyzone cessna 182 ep rtf 2.4 radio mike robson Aircraft - Electric - Airplanes (FS/W) 3 Apr 07, 2012 08:23 PM
Discussion How to set up and trim an EP glider JJ460 Electric Sailplanes 2 Mar 24, 2012 08:27 PM
Wanted Wanted, Electric flightnose cone for Calypso contest F3B glider graham johnson Aircraft - Electric - Airplanes (FS/W) 0 Dec 06, 2008 04:35 PM
