Old Yesterday, 10:46 PM
Farmer
United States, CA
Joined Oct 2011
Build Log
Beginner Vac U Tug Jr Recovery Boat Build
Hey guys i'm attempting my first build on a scale model, well i am not exactly sure if its a scale build but its my first time attempting to build a displacement hull. Lets get started.
First impression the Vac U Tug Jr kit is very well thought out comes with almost every thing you need to build it and the instructions are really easy to follow.
here are the instructions i printed out
Description:
what comes with the kit
Description:
First part tells you to put grease in the stuffing tube
Description:
The grease it comes with and the stuffing tube
Description:
How to apply the grease
Description:
Pushing the shaft back in the stuffing box making sure not to get any grease on the outside of the stuffing tube
Description:
next you want to mark the shaft at 3/8 of an inch
Description:
Drill a hole where marked on the bottom of the hull for the rudder bearing
Description:
should look like this
Description:
Next it says to cut open the stern tube hole
Description:
TBC
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Yesterday, 10:47 PM
Farmer
United States, CA
Joined Oct 2011
Part 2
cutting the stern tube exit
Description:
next you want to sand the skeg reinforcement
Description:
sand where the skeg reinforcement will be glued in the hull
Description:
mix epoxy for the skeg and place some on the bottom of the skeg
Description:
Old Yesterday, 10:48 PM
Farmer
United States, CA
Joined Oct 2011
reserved 2
Old Yesterday, 10:49 PM
Farmer
United States, CA
Joined Oct 2011
reserved 3
Old Yesterday, 10:50 PM
Farmer
United States, CA
Joined Oct 2011
reserved 4
Old Yesterday, 11:24 PM
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
I take it, you do NOT, want any questions, or comments.
CaptCB is offline Find More Posts by CaptCB
Old Yesterday, 11:42 PM
Farmer
United States, CA
Joined Oct 2011
no yes i do want questions and comments and help of course sorry i should have put discussion rather than build log will change it.
thanks
Capt
Old Yesterday, 11:52 PM
CaptCB's Avatar
Joined Aug 2011
I was referring to, was the blocked, post spaces. What I was going to ask was, had you thought about "adding" a soldered on tube, for greasing your prop shaft, stuffing box? It would make your life easier, in the future.
Keep it listed as a "Build Log", as that is what you have.
Old Today, 12:21 AM
Farmer
United States, CA
Joined Oct 2011
No I have not thought of that I will look up how to do that and see if I can solder on A tube for greasing the shaft.
I reserved those posts for more pictures incase some other beginner wants to see all the info on one page.
Thanks again Capt
Old Today, 12:44 AM
CaptCB's Avatar
Joined Aug 2011
This is what I had in mind. This is my 12'' Truckable Pushboat. I can "add" grease, at any time, and get it much fuller, than "just pushing the shaft into the geased tube".
Old Today, 01:26 AM
Farmer
United States, CA
Joined Oct 2011
This is what I had in mind. This is my 12'' Truckable Pushboat. I can "add" grease, arrive time, and get it much fuller, than "just pushing the shaft into the geased tube".
Oh ok I see how thats done. Looks simple enough to do, only problem is that I had already glued the stuffing tube in but I can still drill a hole and I got some low temp solder paste I can use to tack the tubes in place then add some jb weld.
Btw my tug is already built i'm just sharing my experience as a beginner building this tug. But since my top half and bottom half is not glued together its just held together by a rubber bumper I can still do all these mods you and others suggest I am learning alot from this build made my first brass soldered rails and bollards.
Thanks again
Farmer
Discussion where to get railings for top the vac u tug jr pilot house f.a.r.m.e.r Scale Boats 8 Mar 01, 2015 04:51 PM
Build Log Building a Vac-U-Tug with my 5 year old daughter andyzib Dock Talk 32 Sep 23, 2014 07:52 PM
For Sale AUS: Vac-u-Boat Tug Jr kit, Rx ready sponginator Boats (FS/W) 4 Sep 01, 2014 03:30 AM
Question Zipp Tugster vs Vac-U-Boat Tug Jr for First Kit Build? Gimpdiggity Dock Talk 49 Sep 01, 2014 02:10 AM
Build Log Another Vac-U-Tug Build Andre Anderson Dock Talk 8 Aug 31, 2014 02:50 PM
