Old Mar 01, 2015, 10:41 AM
RanDavari's Avatar
Joined Oct 2011
Question
How to Build the motor mount of SkyWalker 168cm?
Hello all,
I'm building my skywalker 168cm and the Circle original plywood That comes with the plane Too small for my motor mount...
My motor is - ax2814c.
So from what I understand Should i use with larger plywood then the original circle plywood.
like this - (From what I saw on the Internet)
https://mpxflyer.wordpress.com/setup...r-motor-mount/
So my question is who i need to build the motor mount with this two plywoods?
i need to glued the two circle plywoods Together and the small plywood circle need glues directly to the EPO?
And then need to connect the motor mount to the plywood with screw??
Someone could explain how to build the motor mount with two circle plywoods please??
Thanks and sorry about my english
RanDavari is online now Find More Posts by RanDavari
Discussion Skywalker 168cm FPV plane Fergus FPV Aircraft 18862 Feb 26, 2015 03:00 PM
Discussion Best Motor for Skywalker for 168cm slaterm61 FPV Talk 4 Jun 10, 2012 08:13 AM
