Old Jun 10, 2014, 01:59 AM
kin
Composite factory
Joined Sep 2007
Smartmodel Viggen EDF90-100 full composite
I have to start this project today for the Viggen , Size will fit 90-100mm fan and member here very helpful let factory much easy to start the project , Now i waiting the plastic models come and will use the internet some 3 -View drawing for the molding work . I will let it full composite ,hollow mold wing , epoxy fuselage . now is the time to make the fuselage length , I guess the target flying weight about 2.3-2.5kg roughly . so power set 6s upto and 3kg power thrust in target .I will find a CS fan to test . cnc ep retract is standard . but it have a special mechanic i need to solve the problem , because landing gear posite is very thin . i need a extra parts to extend the retract shaft to (rotation the leg) , it is a special mechanic for this model . Just this point and no other problem .
kin is offline Find More Posts by kin
Old Jun 10, 2014, 02:19 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
What scale would that be?
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 10, 2014, 04:22 AM
Now, what does this button do?
Nukiwi's Avatar
Christchurch. NZ
Joined Dec 2009
Originally Posted by kin View Post
I have to start this project today for the Viggen , Size will fit 90-100mm fan and member here very helpful let factory much easy to start the project , Now i waiting the plastic models come and will use the internet some 3 -View drawing for the molding work . I will let it full composite ,hollow mold wing , epoxy fuselage . now is the time to make the fuselage length , I guess the target flying weight about 2.3-2.5kg roughly . so power set 6s up to and 3kg power thrust in target .I will find a CS fan to test . cnc ep retract is standard . but it have a special mechanic i need to solve the problem , because landing gear posite is very thin . i need a extra parts to extend the retract shaft to (rotation the leg) , it is a special mechanic for this model . Just this point and no other problem .
Please, make me number one on the order list! (Or the test fly list too )
Nukiwi is offline Find More Posts by Nukiwi
Old Jun 10, 2014, 05:11 AM
Brisbane, Australia
Hey Kin,
You should already have a plastic model if it, I had it send a long time ago....
dave
ticketec is offline Find More Posts by ticketec
Old Jun 10, 2014, 07:51 AM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Target weight is impossible. Expect 4-5kg.
Don't get me wrong, I think it is a great project too.
4stripes is online now Find More Posts by 4stripes
Old Jun 10, 2014, 07:58 AM
kin
Composite factory
Joined Sep 2007
Originally Posted by ticketec View Post
Hey Kin,
dave
Sorry Dave ! i have one last year , but i think in old factory , so i find a new one better .For the size i have measure a size in old topic , so i can find out it .Now i have enough man power to make this models . Of couse now is doing the Bae Hawk wing sample . But not effect R&D dept .So i can work both same time .I never forget your help , so you will have the number 0001 first model .
Old Jun 10, 2014, 08:33 AM
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Hey Kin,
dave
Yeah, didn't you buy that for him on your own dime Dave?
SkylineFlyer is online now Find More Posts by SkylineFlyer
Old Jun 10, 2014, 09:38 AM
kin
Composite factory
Joined Sep 2007
The size is 1:9 wing span 46"
Old Jun 10, 2014, 09:46 AM
Joined Dec 2008
Now your talking, that gives you a length of 71.66" , big enough for 8s to 12s.
Old Jun 10, 2014, 10:10 AM
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Kin make it specific for the current generation 90 mm fans. Jet Fan 90 and Schubeler AXI-HDS
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jun 10, 2014, 11:23 AM
Joined Feb 2006
kin,
Good show for a Viggen dedicated thread. However, your three-view drawing is for AJ-37. Majority voted for JA-37 so far and the 1:48 plastic model is a JA-37 as well:
http://www.tarangus.se/all-new-viggen-model/
I am keeping track of the plastic model availability.
Del
delperena is online now Find More Posts by delperena
Old Jun 10, 2014, 11:53 AM
Joined Feb 2006
Plastic Model
kin,
Here is a reseller from Japan - more convenient and quicker delivery for you:
http://www.hlj.com/product/TGS4803/Air
Projected availability is June 2014.
Del
Old Jun 10, 2014, 12:18 PM
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
1:9 size, very nice
But I think it's going to be much heavier than your predictions.
Please make options for bigger fans than just 90mm, the intakes are big enough at that scale. 110-120 would be nice.
And take your time with the landing gear, Viggen's look so much better with at least semi scale gear.
Can't wait
Mikael is online now Find More Posts by Mikael
Old Jun 10, 2014, 12:47 PM
Joined Dec 2008
Can't wait
I'll bet you'll have too! Four years ago, Feb , the F-15 was projected to be availble . Have you seen one yet??
http://www.rcgroups.com/forums/showp...47&postcount=4
Just check his web site http://www.smartmodel.com.hk/
Aeroplane(Composite) - Electric Ducted fan models - 90mm fan models-- No Product
I will say he has a large thread gallery! Lots of things started, just not finished or availiable. time will tell.
http://www.rcgroups.com/forums/thumb...=threadgallery
Old Jun 10, 2014, 01:54 PM
kin
Composite factory
Joined Sep 2007
Yes ! It is right , some models have not finish in last two factory and spit in business last year , So now work alone is better , Nothing stop me to do my models .Last two year have change business partner two times and study a lot how to make business in china , I will make clever now , working myself much better . At least i have earn some material in hand and enough man power . A lot come out models have disappear the reason is partner change the project to Helicopter and other models they like to do . so i can't focus to finish it , a lot 80% completed master plug have not finish and keep in a corner , It is so bad .Today .no one in front of me. So we can start the project right now TODAY !
Discussion Smartmodel EDF composite ( BaE Hawk /System Hawk for 100-110 mm) kin Electric Ducted Fan Jet Talk 369 Today 08:00 AM
Build Log 1/7 Aermacchi M-346 / Yak-130 / T-100 2x90mm Composite Scratch Build ysolomon Scratchbuilt EDFs 113 Dec 07, 2014 08:14 PM
Discussion Smartmodel new composite rotor blades kin Scale Helicopters 109 Dec 07, 2012 02:32 AM
Sold TF / Smartmodel composite BAE Hawk 70mm Hemikiller Aircraft - Electric - Jets (FS/W) 2 Oct 04, 2012 06:33 AM
Sold K&A F-100 - Full Composite with Servos sbritton Aircraft - Electric - Jets (FS/W) 6 Sep 14, 2012 07:18 AM
