Old Jun 09, 2015, 07:03 PM
Paleomanjim is offline
Find More Posts by Paleomanjim
Joined May 2014
Hobbyking Edge 540 EPP hybrid 960mm
Hobbyking started selling this plane last year, in the fall I believe. It is made by Future Models. There was not much discussion about it and I really like my HK Edge 540T EPP hybrid 1200mm so I decided to try this smaller one out.
The plane was delivered yesterday and I finished the build and maiden this morning. Overall it is a nice plane and fly's fairly well. It does not compare to the larger Edge 540T however.
Strengths: Very smooth flyer. Nice looker. Very floaty. Easy to hover and harrier.
Weaknesses: Flimsy fuselage, not enough CF used to stiffen. Performs slow 3D well, but poor at high energy maneuvers like pop tops and knife edge spins and tumbling. I believe the fuselage flexing is damping the control inputs resulting in lagging performance.
Anyway, here is a short video showing the build and maiden flight for anyone considering this plane. Although I do not have one of the Skywing 38" EPP hybrid models I suspect they are probably a better choice, although again this plane is OK for what it is......
Hobbyking Edge 540 3DEPP 960mm build and maiden (5 min 32 sec)
Paleomanjim is offline Find More Posts by Paleomanjim
Old Jun 10, 2015, 02:16 AM
1101 is offline
Find More Posts by 1101
New Zealand, Auckland
Joined Dec 2008
I maidened mine on the weekend....finally.
I was surprised at its weight, I expected much lighter.
Yep , floaty, very stable, easy to fly, can fly in small areas. But I wouldnt buy another.
It balances out easily, not tail heavy like some HK planes.
I used a Hengli BM880-2316 880KV motor, cheap from Goodluckbuy, & YEP esc (has a grunty SBEC).
more info here, including the other similar planes HKing sells
1101 is offline Find More Posts by 1101
New Product Future Model 48" full-fuse hybrid Yak 54 EPP - stiff wood frame with EPP skin! groovejet 3D Foamies 28 Jun 28, 2015 05:01 PM
Build Log PART 1 - 38 Slick 540 EPP Hybrid Step By Step Build Log and Guide - By Aerobeez Aerobeez Aerobeez 3 May 26, 2015 04:54 PM
Video 55" Edge 540 EPP Hybrid Rainy Day with Santiago Perez! Aerobeez Aerobeez 0 May 06, 2015 12:59 PM
Sold Hobbyking EPP/balsa edge 540 airframe hi2nr Aircraft - Electric - Airplanes (FS/W) 1 Sep 08, 2014 01:26 PM
