UK, Cardiff
Joined Dec 2008
http://www.antex.co.uk/product.asp?s...D=185&P_ID=892
Very good indeed. Can cope with Deans connectors through to surface mount stuff, just use the appropriate bit and the temperature control. |
Those are great soldering stations, but a lotta bucks in USD
![]() Here's a good Weller station, more readily available on this side of the pond. http://www.cooperhandtools.com/brand...ing%20Stations The WCL100 is a nice, reasonable priced unit. If the irons heating element goes kaput, you just buy a new weller 40W iron, as the cord from the iron to the station is just a normal wall plug. Pete |
San Carlos, CA
Joined Mar 2004
If you're serious about good soldering capability across the board there is absolutely nothing even remotely comparable to the Metcal line of soldering irons. Very low thermal inertia (due to how they work), wide range of tips, and the entry-level is only USD250.
Serban |
I have used this soldering station for years, and it works great. It has been dropped, kicked, burned up in a lipo fire, but it just keeps on working. I use it for soldering through hole, surface mount, and I turn up the heat, use the thick part of the tip and solder Deans connectors. It heats up in about 30 seconds, and it costs $42.00. I really need to buy another one so I'll have one at the shop, and one at the house.
It's the only iron I use Dan |
New York City, USA
Joined Oct 2003
Just an amazing unit. And no need to adjust temperature either. http://www.okinternational.com/product_soldering/ps_900 |
San Carlos, CA
Joined Mar 2004
For deans and 14 AWG and bigger wires I use plain 60W iron on a dimmer. For smaller electronics and servo-size wires I very much like Aoyue 936. It's based on Hakko design and use Hakko tips. The best iron I had!
http://www.amazon.com/Aoyue-Solderin.../dp/B001RNG2PG |
Raleigh,NC
Joined Nov 2000
It is also a clone of the Hakko 936 and takes the same tips which are readily available. Availability of tips is one thing to consider when buying an iron. If you get an off brand iron, make sure it uses the same tips as a major brand so you can be assured of availability of tips. |
| Thread Tools | |
| For Sale Metcal PS2E-01 soldering iron (DFW) | lehma | Non R/C Items (FS/W) | 5 | Feb 09, 2013 06:45 PM |
| Discussion soldering station recommendations? | motoguy1 | The Builders Workshop | 16 | Feb 20, 2011 07:44 PM |
| Discussion my 4#3b - I killed it with a soldering iron. should i go brushed? | Jas101 | Micro Helis | 3 | Sep 11, 2010 03:51 PM |
| Sold Cold Heat cordless soldering iron - $12 shipped! | MinneFlyer | Aircraft - General - Miscellaneous (FS/W) | 4 | Sep 07, 2010 02:25 PM |
| Question Mini butane soldering iron | mexico | The Builders Workshop | 3 | Aug 31, 2010 11:10 AM |
