Old Oct 11, 2012, 06:23 AM
Joined Aug 2009
Nice flying! Makes a guy want to take his F35 out and do some tumbles.
19000rpm is offline Find More Posts by 19000rpm
Old Oct 11, 2012, 01:50 PM
Joined Dec 2010
Originally Posted by johnbone View Post
I still get a lot of fun out of her at the local park.
How have Your landing gears held up flying off/onto, the grass ?
Bille
BilleFly is offline Find More Posts by BilleFly
Old Oct 11, 2012, 06:43 PM
AMA 42272, from the 1970's
DXStickman's Avatar
United States, AZ, Kingman
Joined Oct 2007
I just flew mine today for the first time...what a thrill. Mine is from Hobby Lobby, but I am sure it is the same as the FreeWing. One issue I noticed was that the foam around the nozzle wasn't put on straight so I removed it and re-glued it in the correct position. I am using a DX-8 so I was able to slow down the retracts to keep them from banging into position. The retracts do look like they will break if landed too hard... I greased my first one, got lucky.
Question on the VT...the manual said to use the rudder mix for the left/right on the nozzle. I set mine up to mix on the aileron. Is there a reason it is suggested to mix using the rudder? The first time I used the VT really got the heart rate up...what a kick!
DXStickman is offline Find More Posts by DXStickman
Old Oct 11, 2012, 06:59 PM
You are a "go" for reentry
High Orbit.....
Joined Jun 2009
You did what?
YAW is rudder. The F35 has a single nozzle at the aircrafts cg axis so mixing it with roll will add a yaw action where may only want roll.
Because the model doesn't have rudders they instruct to have the TV assume rudder control as long as power is being applied. You see this in the majority of the TV models setups absent of rudders.
You're basically are flying Mod2 trying to get roll from yaw. This an old school kind of thinking and unnecessary if you actually have the control given to you.
So! You have it Y'd to the wrong controls. It should be Y'd to the steering.
Its not going to crash you but its not going to allow you to control it correctly. That said it does assist in a crabbing configuration.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Oct 11, 2012, 07:29 PM
DXStickman's Avatar
Joined Oct 2007
That makes sense...I changed it back to Rudder.
Old Oct 12, 2012, 03:07 AM
Australia, WA, Perth
Joined Jun 2009
Bille
I changed them to servoless units long ago. Mains were ok but the stock front gear collapsed from day one.
John
johnbone is offline Find More Posts by johnbone
Old Oct 12, 2012, 03:08 AM
Joined Jun 2009
Thanks. The hard part with these small cams with slight wide angle lens and no zoom is keeping the plane in close so it doesn't look like a speck in the sky. Easier to keep a blowfly buzzing your head
John
Old Oct 12, 2012, 07:05 AM
Joined Aug 2009
John
So true. A common short fall of many head cam vids you avoided.
Old Oct 29, 2012, 11:01 PM
DXStickman's Avatar
Joined Oct 2007
I now have about 15 flights on my F-35 and I am having a weird problem. My nose gear doesn't always extend all the way...takes a couple of cycles to get it down and locked. It always works on the bench...only fails in flight. I have removed the gear and made sure it isn't hanging up somewhere, the servo seems strong and doesn't show any signs of broken gear teeth. Has anyone just replaced the nose gear with a servoless nosegear and still used the stock mechanical gear on the main landing gear? I have a set of E-flite gear...not sure if that would be the best choice. Any suggestions??
Old Oct 29, 2012, 11:55 PM
swede
denial15's Avatar
10-95
Joined Aug 2005
I'm in the process of that now. I just can't find a good way to get the steering connected.
denial15 is offline Find More Posts by denial15
Old Oct 30, 2012, 12:58 AM
Tape n' glue, Good as New!
Chilliwack, B.C. Canada
Joined Aug 2009
I just gave up on the steering and put reg. servoless retracts in 4 mains and nose. Works pretty good. I just line her up when I put her down, n' wot it into the sky!
jussyjonny is offline Find More Posts by jussyjonny
Old Oct 30, 2012, 07:27 AM
Joined Aug 2009
You can try changing the endpoints on the gear channel. I use a DX7 and set the extended position at 137%. That seems to work. It locks and doesn't fold. At least on smooth surfaces.
I think the Eflites are too big for this plane. Check back a little in the thread and you'll find a link to some HK nose and main retracts. They are just the right size. I'm going to use them in the F35 and Su34.
I haven't done it yet, but I think the strut on the HK steerable nose gear can be modified to fit the stock oleo and steering mechanism.
Old Oct 30, 2012, 04:41 PM
DXStickman's Avatar
Joined Oct 2007
Thanks for the suggestions. Today I took the nose gear apart and didn't see anything that would cause it to hang up. I replaced the pushrod with a straight piece of wire. I did reset the end points to ensure a full lock on all gear in both the up & down positions. I am using a DX-8 so I am able to set the speed of the gear servos...I did have them slowed down quite a bit, so I increased the speed just a bit. I will fly it again tomorrow and see what happens. Next will be a servo replacement, and if that doesn't work a complete re-do of the gear to servo-less retracts.
Old Nov 02, 2012, 03:02 PM
DXStickman's Avatar
Joined Oct 2007
Yesterday I discovered the cause of my nose gear problem. The pushrod for the nose steering needs to be secured so that it can not move sideways when the gear is raised or lowered.
On my second flight today I had an in-flight failure of the right outboard horizontal stabilator hinge...it pulled out of the foam. It caused an uncontrolled roll, followed by a vertical dive into the ground from about 100 feet. I saw the tail come apart in the air. Plane is totaled, electronics seem OK. Cheap Chinese glue doing it's magic once again.
Old Nov 02, 2012, 03:05 PM
Joined Aug 2009
Yeah, I even replaced mine (as is highly recommeded) with different hinges and they are constantly coming out! I've reglued them in several times... I check them before every flight now. Sorry about your loss
Idea X-Flight EDF-55 F-22 w/Thrust Vectoring MidNiteCM Foamy EDFs 4 Feb 07, 2008 04:24 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
Video Mini-Raptor W/ thrust vectoring LLoo Electric Plane Talk 0 Aug 19, 2007 10:57 PM
Discussion Foamie EDF w/ thrust vectoring? Elvis48 Electric Warbirds 2 May 09, 2007 08:16 PM
Idea Mr. Boogies JSF F-35 with thrust vectoring tow Electric Ducted Fan Jet Talk 26 Jan 16, 2006 07:45 PM
