Old Jun 08, 2002, 07:14 PM
Plane hugging cat
Vonbaron's Avatar
Mackay Queensland Australia
Joined Sep 2001
Electric free flight motor
I can't help myself. I ripped apart a cute little free flight cub to see what the motor was. The magnets are strong, there is some cogging. It pulls 5 amps from this 4 inch prop with only 2 180mah nicads!
Would this motor be of use in a gearbox for something more R/C like? Or should I just stick it back into the free flight model and go fly?
Vonbaron is offline Find More Posts by Vonbaron
Old Jun 09, 2002, 04:06 PM
Hacker motoren rules :)
Philip Thulin's Avatar
Sweden, Östergötland County, Norrköping
Joined Sep 2001
5 Amp?
Oh my god!
a speed 280 draws half of that!
I wouldent use it in an RC plane, put it back in the cub and go fly
Good luck!
/Philip
Philip Thulin is offline Find More Posts by Philip Thulin
Old Jun 09, 2002, 04:51 PM
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
AGREED! Dont let the cows eat the cub....
Paul
Paul Penney is offline Find More Posts by Paul Penney
Old Jun 09, 2002, 07:02 PM
Houston Texas
Joined Mar 2001
I say put a much smaller prop to see if you can cut the current down?
Philip
fill is offline Find More Posts by fill
Old Jun 09, 2002, 08:01 PM
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
I think this motor is heavily overpropped, but it might be a good motor when it can turn a bit faster. Give it a good amount of gearfactor, say 5:1, and choose a prop so that it pulls 2A from 4 cells, and it might be a winner.
BTW, the cogging can be a sign of a strong magnet (which is good) or big gaps in the rotor (which are bad).
jberg is offline Find More Posts by jberg
Old Jun 10, 2002, 12:10 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Looks and sounds similar to the Cox Motor I pulled out of the Higway Patrol, and replaced with an N-20 Geared on 4x120 cells.
Gene Bond is offline Find More Posts by Gene Bond
Old Jun 10, 2002, 07:14 AM
Plane hugging cat
Vonbaron's Avatar
Joined Sep 2001
Even on a 5:1 gearbox and 6" prop from a rubber powered model it draws too many amps and doesn't blow as much wind as a GWS IPS. Oh well, guess I'll keep it for free flight.
Zero RC conversion Hobbico's Flyzone Electric Free Flight thecurriculum Parkflyers 35 Jan 14, 2013 05:36 AM
Alert anyone built an electric free flight glider? b36roxs Free Flight 2 Apr 20, 2007 08:35 PM
electric free flight rotccapt Free Flight 7 Nov 24, 2004 11:51 PM
Electric Free Flight Competition SteveS Electric Plane Talk 1 Dec 07, 2001 04:05 PM
