Old Jan 21, 2015, 10:31 PM
Joined Jan 2015
Question
Battery suggestion
Hi people!
I am completely new to the multirotor world and I am assembling my first hexacopter now! And it goes like this.
1.Frame - Flame wheel f550
2.Flight controller- Pixhawk
3.ESC - 15A OPTO ESCs
4.Motor- 920kv
I am planning to have a GPS, IMU, camera and and some sonar sensors installed on it.
What will be an ideally good battery for this application? I am planning to get a 4S Lipo 5500 mAh 40C battery.
Will it give me a good flight time?
Is there any math to calculate the flight time that can be obtained approximately?
Also need a suggestion for Rc transmitter and receiver to be used with Pixhawk fc?
mugesh is online now Find More Posts by mugesh
Old Jan 22, 2015, 03:42 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
Welcome to the forum
You're new to the multirotor world, but are you new to RC flying in general? My feeling is you're planning to commit too much money if you haven't flown before.
Having said that, to respond to your questions, how much flight time your proposed battery will give you depends on what payload you're carrying. The only way to calculate or estimate the flight duration is to know how many amps your setup will consume in the hover, and that depends mainly on its weight. I think that 5000-or-so mAh is a good starting point though.
As for radio gear, you need any transmitter/receiver that has at least six channels -- probably more if you want full control of your camera. I use Futaba myself, but pick any good name brand (Spektrum, Hitec, Frsky, etc.) and you'll find plenty of people who swear by them
You'd be better asking further questions in the dedicated multirotor sub-forum by the way
abenn is offline Find More Posts by abenn
Old Jan 22, 2015, 07:45 AM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Originally Posted by mugesh View Post
Hi people!
4.Motor- 920kv
Please provide a link to all of the above items.
You have to give more motor specifications than that. Voltage? Maximum amps?
I am planning to have a GPS, IMU, camera and some sonar sensors installed on it.
Sonar? I thought you said hexacopter, not submarine!
I'm confused. Your title is what is a good battery. Now you state what you are going to use???
Who knows? What is the gross weight of the aircraft? What is the average current draw of the motors and additional electronics?
Yes there is. IIRC it is AH/60xA
(AmpHour of the battery divided by 60 times the current in Amps = flight time in minutes.)
I am going to provide some advice. You obviously are new to this area of RC. You would be much better off starting with a proven system. You are allowing to many variables into your system to have a reasonable measure of success.
As noted above always provide full specifications and links to equipment you reference. Without that information any answers you receive contain a significant amount of speculation.
But at any rate, Good Luck.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Discussion 12v or 24v Field battery suggestions SteelRainSpo Batteries and Chargers 12 Jan 02, 2015 10:39 AM
Discussion Please help What Battery do you suggest? PJ Faller Power Systems 4 Nov 22, 2014 02:45 AM
Discussion Traxxas Slash Platnium battery suggestions? rcdishman Off-road Cars 1 Nov 10, 2014 03:04 PM
Discussion Suggested upgrade battery for V252 Pro Skylark? LittleFish Mini Multirotors 11 Oct 28, 2014 12:14 AM
Wattage Hawk - battery suggestions / other suggestions? PLD Parkflyers 33 Dec 04, 2003 11:07 PM
