Old Oct 08, 2007, 05:26 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Thick wing micro
First, is 3 ozs light enough to be a micro? If so, I made a thick wing plane that seems to have a lot of promise for a small area.
http://www.rcgroups.com/forums/showp...postcount=2151
stanordave is offline Find More Posts by stanordave
Old Oct 08, 2007, 05:36 PM
Pete P is offline
Find More Posts by Pete P
Micro Flyer, Big Poster
Pete P's Avatar
Joined Feb 2005
Indoor, yes, micro, most likely no :-D
<incorrect statement removed>
Pete P is offline Find More Posts by Pete P
Old Oct 09, 2007, 05:04 PM
crossup is offline
Find More Posts by crossup
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
Have to disagree with you on the symetric wing not generating a lot of lift- its true at zero angle of attack it wont produce any, however even at only +1 deg it will...rather than go into a treatise on aerodynamics, just consider that ALL scale aerobatic models use symetrical airfoils yet most can easily pull 30 gees..
remember you can only pull as many gees as you have excess lift available..ie to pull 30 gees the wing must fly and NOT stall while carrying 30x the weight of the model.
I for one wont call that "not much lift"
That wing seems like it would have alot of drag, and it being symmetric, wont generate much lift.
crossup is offline Find More Posts by crossup
Old Oct 09, 2007, 10:33 PM
dwkwingnut is offline
Find More Posts by dwkwingnut
AMA 218183
Reseda [san fernando valley]CA, USA
Joined Aug 2007
First flight? Cant wait till you get her dialed! Very nice. It's harder to make em fly slow than fast. With the power we have these days, drag isnt a problem, it's a solution.
dwkwingnut is offline Find More Posts by dwkwingnut
Old Oct 10, 2007, 04:22 PM
Pete P is offline
Pete P's Avatar
Joined Feb 2005
Corrections noted :-D
Discussion Mylar Q-Wing Micro Flying Wing mharms Scratchbuilt Indoor and Micro Models 18 Aug 08, 2007 07:13 PM
Discussion Thick wing section Curare Sailplane Talk 5 Oct 27, 2006 05:08 AM
how thick of a wing can i get ... Mighty Mik Composites Fabrication 3 Jul 02, 2004 09:11 AM
Glow Planes / Thick Wing Observation Phat2Wheel The Builders Workshop 9 Oct 27, 2003 09:25 AM
Flapping Wing Micro Air Vechile joe price Scratchbuilt Indoor and Micro Models 2 May 28, 2003 09:32 PM
