Old Dec 19, 2010, 12:57 AM
kurt112345 is offline
Find More Posts by kurt112345
United States, WA, Renton
Joined Aug 2010
fastest fly fly, hobby top gun
I want to build another 90mm edf which one of the fly flys or hobby top guns has the best airframe for speed? most aerodynamic airframe?
kurt112345 is offline Find More Posts by kurt112345
Old Dec 19, 2010, 03:05 AM
Frenche is online now
Find More Posts by Frenche
ooooh yeah
Frenche's Avatar
Ballarat, Victoria, Australia
Joined May 2004
probably the Mirage, ExtremeRC in Australia has made some wicked fast ones
Frenche is online now Find More Posts by Frenche
Old Dec 19, 2010, 03:55 AM
yakhakker is offline
Find More Posts by yakhakker
still trying to get it right
yakhakker's Avatar
Belgium, Région wallonne, Tournai
Joined Feb 2009
Yep i'll go with that,take a look at the Jepe ones
yakhakker is offline Find More Posts by yakhakker
Old Dec 19, 2010, 05:38 AM
UltimateX is offline
Find More Posts by UltimateX
There's never enough power
UltimateX's Avatar
Schötz, Switzerland
Joined May 2009
Jepe is a good choice
Hi
In our club we have very good experience with the Jepe mirage 2000. There are about 4 to 5 around.
- High speed: 253 km/h (157mp) logged by GPS
- Very good handling and maneuverability
- High alpha and low speed characteristics are just fun
Here is a build thread
http://www.rcgroups.com/forums/showthread.php?t=1197638
We do our mirages without retract.
- Less weight
- Better stability
- Easy bungee launch
Alternatively the F22 is said to be a little faster. I can tell you a soon as I finished mine. Here's the build log.
http://www.rcgroups.com/forums/showthread.php?t=1342405
there is a cool mirage200 video, too
Michael
UltimateX is offline Find More Posts by UltimateX
Old Dec 19, 2010, 10:28 AM
ooooh yeah
Frenche's Avatar
Joined May 2004
Yep the Jepe fast foam ones are quick as well (forgot about them in my 1st post). It's good because the cheapest of all the airframes (well that I can find at least) is the Mirage. Mine will probably be lucky to hit 100mph with only 1600watts but that's fast enough for me right now.
Old Dec 20, 2010, 10:55 AM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
I'm building the Mirage right now. Mine isn't going to be a speed demon, but who knows. As far as my fastest FlyFly plane, well, its my Hawker Hunter. It does 125mph on the straight. No dive required.
Jon
Here is a link to my build thread on it and a link to my flights. Hope you like.
http://www.rcgroups.com/forums/showthread.php?t=1287406
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Dec 20, 2010, 01:12 PM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Originally Posted by UltimateX View Post
Hi
- Less weight
- Better stability
Michael
I bought myself now as well the Mirage from Jepe the Fast Foam version.
I am installing an ARC 3665 Setup with 3.6kg Thrust on 6S which will draw around 90-95 amps, so I think a good 6000mah Battery will be need to get a good 4-5 minutes mixed throttle flight.
I was thinking of getting Retracts as well,but seeing that planes explode like in the air, I am thinking twice about it.
It is going to be very interesting....
neversommer is offline Find More Posts by neversommer
Old Dec 21, 2010, 03:00 AM
Joined Aug 2010
hows the mig-29? u think it would be fast with 2 90mms. so the fast foam jets are modified fly fly jets?
Old Dec 21, 2010, 03:09 AM
Joined Aug 2010
i have the f-4 right know with a mega wemo setup in it and power and speed hasnt been great maybe 75mph on 6s i have a video in the f-4 build thread of a pass almost need a calender to time it but other then that its very cool edf to fly i will probley try a arc 36-75-1.5 with 8s same as skylinefury hawker hunter but half to have atleast 2 of these 90mm edf. so far iam lookin at the mig-29, the mirage, hawker hunter and f-86, at least one will be my next one.
Old Dec 21, 2010, 07:21 AM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
Elaborate please?
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Dec 21, 2010, 07:27 AM
Luzern/Switzerland
Joined Aug 2008
Originally Posted by Jacques.Eloff View Post
Elaborate please?
People build the Jepe Fast Foam Mirages and glassed them, some without some with retracts...
During flight the wings kinda "exploded" due to the high speed.
Reason for this is that the servos were too far away placed and not in the position which jepe recommends..also maybe the elevons were not glassed with epoxy for high speed setups.
I spoke with him today and he said if you do it as told from the instructions, the mirage even with 4.5kg thrust and 10s will hold up.
I still need the length of the flyfly original struts that come with the mirage..the measurements can nowhere be found !
Could anyone tell me the length of these struts please ??
I will get the new RC Lander full metal retracts but I need to know the approximate length.
Old Dec 21, 2010, 12:50 PM
UltimateX's Avatar
Schötz, Switzerland
Joined May 2009
Yes, they are based on the FlyFly kits.
- Modified inlet ductings and smooth insides (for you to construct of course)
- Relocated servo positioning to prevent flutter
- Better and stronger linkages
- Different center of gravity (FlyFly is always tail heavy)
- Glassed surface
The work you put in the foamy makes the difference between a flying FlyFly foam jet an a quite powerful and well handling Jepe fast foam jet.
Michael
Old Dec 21, 2010, 06:36 PM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
You should also add in a carbon fiber spar of some type. As I recall from the video, it was the wing which separated. These are only foam jets and once you start getting into 10S lipos and some of those fast speeds, the wings/fuselog need a bit more structural integrity.
alexandermh is offline Find More Posts by alexandermh
Old Dec 22, 2010, 12:42 AM
Luzern/Switzerland
Joined Aug 2008
I do have some carbon fiber spar at my disposal and may reinforce the wings around the retracts a little.
My main concern is the installation of the retracts..especially the nose retracts..I guess there needs to be quite a bit of reinforcements on that side as well.
The whole Mirage will be glassed only outside with glass tissue and pu finish. The ailerons will get epoxy glassed since a powerful fan will be build in.
Neversommer.
Old Dec 22, 2010, 01:56 AM
Joined Aug 2010
hows the mig-29 for speed?
Discussion hobby top gun mig 15 corsair nut Foamy EDFs 167 Jan 05, 2015 03:35 PM
Build Log Hobby Top Gun / EJF.COM MIG-15 Build CRCJA Foamy EDFs 225 Feb 15, 2014 03:02 PM
Discussion My NEW Huge 120mm EDF Hobby Top Gun MiG-15 wingspan100 Foamy EDFs 127 Jul 27, 2013 06:28 PM
Sold Hobby Top Gun 90mm fan and 1600KV Motor CRCJA Aircraft - Electric - Jets (FS/W) 4 Jan 27, 2011 02:34 PM
New Product Hobby Top Gun L-39 cockpit upgrade sparks Foamy EDFs 12 Dec 06, 2010 06:43 AM
