Old Aug 17, 2015, 09:15 AM
dickmcjohnnson is offline
Find More Posts by dickmcjohnnson
Joined Aug 2015
LRP Speedbird Corsair (HK Funfighter) thrust angle
My nee unflown LRP Speedbird Corsair (appears to be a repainted HK Funfighter) has no downthrust. Thrust angle seems to to be up/right?
Can this be correct?
dickmcjohnnson is offline Find More Posts by dickmcjohnnson
Old Aug 17, 2015, 12:08 PM
Foam Addict. is offline
Find More Posts by Foam Addict.
Destroyer of foamies
United States, CO, Denver
Joined Jan 2013
Possibly. Since its a low wing plane, it might need a little up thrust to counteract the strong down pitch from the higher mounted motor. How much up thrust? A degree or 2? There should be 4-5 degrees of right built in.
Foam Addict. is offline Find More Posts by Foam Addict.
Old Aug 17, 2015, 02:21 PM
Joined Aug 2015
Cannot measure it. It's way more to the right as it is up.
So, if the angle to the right is 4 to 5 degrees, the up angle will be no more than 1 1/2 degrees.
I'll give it a shot the next calm Saturday/Sunday morning.
If she is well balanced she is going to fly anyway.
Old Aug 22, 2015, 02:50 AM
Joined Aug 2015
Fatal crash at first flight.
She didn't fly. Almost no control authority on elevator. She climbed a bit and went straight into the ground and disintegrated.
Discussion LRP Speedbirds. pshelton Electric Warbirds 13 Mar 01, 2015 01:38 PM
Discussion LRP Speedbird BF 109 in new design ;-) russcramer Electric Warbirds 0 Oct 09, 2014 11:01 AM
Discussion Dynam 4FU Corsair thrust angle Stiznef Electric Warbirds 1 Mar 29, 2014 10:47 AM
Discussion Alfa Corsair motor thrust angle? Stephen Shioi Electric Warbirds 13 Jun 25, 2008 12:42 AM
Motor thrust angle GWS Corsair. Big_Bird Parkflyers 1 Oct 30, 2005 04:16 PM
