Old Jul 03, 2014, 04:48 AM
Germany
Joined Nov 2006
The gear will cost almost as much as the plane itself...
Planning to put a Dualsky 5050 with 575kv in it, powered by 4s3800. Should be fine for scale flying, have lots of these batteries already on hand. With a 15x8 APC, power should be ok.
Aussie64 is offline Find More Posts by Aussie64
Old Jul 03, 2014, 05:07 AM
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
I use a similar weight motor and it balances nicely with the pack (6S 3300 or 5000) up in front of the servos.
You might find with that Kv and 4S that 15 x 10 will give you a bit better pitch speed, especially at part throttle, and a bit more thrust if you need it
scirocco is offline Find More Posts by scirocco
Old Jul 03, 2014, 05:22 AM
Germany
Joined Nov 2006
Will try that, thanks. As mentioned before, the biggest concern is the ground clearance
Old Jul 03, 2014, 09:27 PM
Joined Jan 2012
About 1/2 the cost but maybe the best mod I've ever done to any plane of mine and it ( the gear) will last a lifetime with great resale value....might lose $30-$40?..if that... because I seldom see them for sale used. Fly safe!
Pilot Fatigue is offline Find More Posts by Pilot Fatigue
Discussion New EPP Super Zoom 4D from SoaringUSA.com build thread hybris 3D Foamies 2467 May 09, 2012 08:24 PM
MicroBipe from Dynamoelectrics.com - Build Thread badbill Parkflyers 116 May 28, 2008 05:48 PM
Micro Flash (from MiBo Modeli) Build Thread Neil Walker Electric Sailplanes 45 Jul 04, 2005 12:38 AM
NIB Hangar 9 Piper Cub 80" WING RJ Reinhard Aircraft - Fuel - Airplanes (FS/W) 0 May 27, 2003 03:07 PM
