Old Nov 02, 2014, 03:56 PM
Deviant
sbstnp's Avatar
Joined Jul 2012
Originally Posted by Makdaddy View Post
what's considered as a good distance for a range check - 30 paces- or?
If you get 40 that's very good.
sbstnp is online now Find More Posts by sbstnp
Old Nov 06, 2014, 05:28 AM
Rchelistuff
Romania, AR, Arad
Joined Nov 2012
Guys, I have a devo 10/100mw power with rx-1002 but at around 500 mt I almost crashed my flip fpv quad due to signal loss, and when I seen the ground coming it suddenly pickef back my input and I could save it. What went wrong? How could I fit an hawkeye lrs tx on my devo? Can it be done?
Tx
cofl10011 is offline Find More Posts by cofl10011
Old Nov 06, 2014, 08:21 AM
Deviant
sbstnp's Avatar
Joined Jul 2012
Tx
Many things could have gone wrong, signal shadowing, receiver sensitivity, trees, etc.
That hawkeye LRS is a PPM module so in theory it should work (even with stock firmware trainer port -> module input). I would recommend running Deviation for full benefits.
Old Nov 06, 2014, 08:35 AM
Rchelistuff
Romania, AR, Arad
Joined Nov 2012
Ok...but how can it be connected to the devo 10? This lrs comes as a module direct fitting to a flysky th9x for example. Anyone used this on a devo? Also os there any chance to import my models in the deviation firmware?
Old Nov 08, 2014, 12:28 PM
Joined Jun 2014
Hello to all.
I have just bought one devo12S.
I want to fly my frsky receiver with telemetry.
I already have a DIYfrsky module rise in my er9x.
The East he(it) possible to go(take) up him(it) in the devo and " to have the telemetry on the devo?
Otherwise, what is the best solution?
I seen well that he(it) had modules there has to go(take) up CC2500 / A7105 and other.
The what is the best?
Thank you
vincentimes is offline Find More Posts by vincentimes
Old Nov 08, 2014, 12:34 PM
Joined Jan 2014
You'll need the CC2500 module. Note that FrSky telemetry support is still in it's early stages.
Here's the module that I have in my Devo12s: http://bit.ly/1w08Z14
mikemacwillie is offline Find More Posts by mikemacwillie
Old Nov 08, 2014, 05:10 PM
Deviant
sbstnp's Avatar
Joined Jul 2012
There is a non-plugable module which could get PPM input off the trainer port on the Devo. Keep in mind I don't have one so I have no idea if it works or not. Deviation is probably your best friend as you can tweak the PPM output.
PM me if you need help with Deviation.
Old Nov 09, 2014, 04:58 AM
Rchelistuff
Romania, AR, Arad
Joined Nov 2012
I am just trying to get 1/1.2 km range on my radio and my devo10+rx1002 fail at ~6-700 mt. This hawkeye lrs is 80$tx module+rx. On the other hand I cpuld get a frsky tx+rx kit for 40$ on hk website and ppl claimed 2. Km range... Don't know where to be heading...Guess the flysky tx compatible with the 9xr is not working with my devo? Tx again
Old Nov 09, 2014, 06:48 AM
Deviant
sbstnp's Avatar
Joined Jul 2012
You can get a CC2500 module, add it to your Devo10, pop the main antenna uFL connector off and attach it to the CC2500 module. Use another short antenna for the stock module or take it off altogether.
I did the above once but I never tested range outside maybe 300m. YMMV.
But, you still need Deviation for this.
PM me if you need a CC2500, I have 2 extra and I'm in Bucharest.
Old Nov 12, 2014, 12:17 PM
Czech Republic
Joined Aug 2012
Hi guys, I have DEVO 10 and deviation 3.0.0 installed.
So I have there all my models programmed (also have a backup of them on my hdd). I'm wondering, if I install the 4.0.1 would be the problem with model configuration? I mean loading them to the updated tx and binding, stick responses...
Have anybody of you had problem with that?
Also what about the range of the DEVO 10 with new deviation, is it better or how is your max range?
I read something about range increase with patch antenna - what is it?
And do you think, the Devo 10 is enough for expensive birds such as 700L? Or should I upgrade for Devo 12? is it more reliable?
Thank for your advices, I know there is quite more questions
djsmeegy is offline Find More Posts by djsmeegy
Old Nov 12, 2014, 02:57 PM
Joined Jan 2014
Copying the model config files should be fine, but make sure you use the rest of the new filesystem. Only copy the models directory from your 3.0 TX. You may need to do some reconfiguration for switches.
Old Nov 13, 2014, 02:58 AM
Czech Republic
Joined Aug 2012
Thank you for suggestions. During this weekend Im gonna do the update. Will keep you posted.
Old Nov 13, 2014, 04:06 AM
Czech Republic
Joined Aug 2012
Originally Posted by sbstnp View Post
The RF module inside has an u.FL connector.
Don't cut the current antenna, get:
1 x u.FL to SMA pigtail ($2.50 part usually)
1 x SMA normal 2.4Ghz antenna (these should be easy to source).
The you just:
a) plug uFL to radio module
b) SMA in to booster
c) normal antenna SMA out from booster
Hello, I just went thru this thread a bit and found your post here.
Do you think its possible to upgrade my Devo 10 by this components?
antenna and cable?
Or the antenna's dBi is too high?
Thank you.
Old Nov 13, 2014, 10:47 AM
Joined Jan 2014
The pigtail is fine, but that antenna has an RP-SMA connector, instead of the required standard SMA connector. There should be a pin in the middle of the antenna connector. Something like this would be suitable: http://www.ebay.ca/itm/Antenna-2-4G-...item1e898cae20
Old Nov 13, 2014, 02:18 PM
Czech Republic
Joined Aug 2012
Thank you! I went thru many items on ebay, so I probably chose the wrong one here anyway thanks!
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 05:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 01:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 12:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 09, 2011 12:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 06, 2011 12:19 AM
