Old Aug 19, 2014, 06:06 PM
Joined Feb 2014
I put this together in 2 hours. No plans, no thought; just cut and try. It glides, but not much more. tried a hubsan prop and my too big 3x2 but I think I need to get a gearbox.
3mm foam board a carbon arrow and a v911 brick.
Description:
dews is online now Find More Posts by dews
Old Aug 20, 2014, 10:54 AM
limmacslim's Avatar
United Kingdom, London
Joined Jun 2012
dews, the f939 gearbox is pretty well priced at banggood & works well.
http://www.banggood.com/WLtoys-F929-...-p-930770.html
You might also want to get some f939 prop's to save messing around with adapters etc. A friend ordered a prop to test, he has not flown it yet but at first glance it seems decent enough. Its quite light so should spin well & its large enough to make decent thrust, maybe not the toughest out there though.
http://www.banggood.com/WLtoys-F929-...-p-930766.html
limmacslim is offline Find More Posts by limmacslim
Old Aug 20, 2014, 01:01 PM
Weltherrschaft will be mine
Germany, SN, Leipzig
Joined Nov 2012
i like the f939 prop....
it seems you have no dihedral, that would help
borkencorter is offline Find More Posts by borkencorter
Old Aug 20, 2014, 02:39 PM
Joined Feb 2014
Yeah. As I said I just cut and glued. Will redo the wing when I have a gearbox that works.
I scavenged the gearbox from a broken v911. Does not look like it is going to work out. I will put a 5x3 on it and chuck it into the wind as soon as it stops raining and gusting.
Old Aug 20, 2014, 02:55 PM
limmacslim's Avatar
Joined Jun 2012
The V911 gearing is way too much, I tried using a cut down v911 frame on the nose before & needed a huge prop to make it do anything interesting. It hung on the prop fine, even did a little bit of vertical flight but did not make enough pitch speed for normal level flight.
a 4:1 gear ratio seems to be the right way to go.
Old Aug 24, 2014, 02:12 PM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Hello, can someone give me a link for the banggood 8mm motors please?
djdavies83 is online now Find More Posts by djdavies83
Old Aug 24, 2014, 09:48 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Thanks epilot, did I see a link somewhere for a pair of 8mm for a quad?
Old Aug 25, 2014, 12:59 AM
Joined Feb 2014
Micro-motor-warehouse.com
Old Sep 13, 2014, 07:39 PM
Joined Sep 2014
After stumbling about on this thread and a lot of read ups, I finally built my favorite - F22 and the Spitfire micro DD models. Both are 8.5mm DD with Hubsan props. F22 is around 28gr AUW and the spitfire is 23.85. Before I post more details - here are the pics:
rajeshsl is offline Find More Posts by rajeshsl
Old Sep 13, 2014, 07:48 PM
Joined Sep 2014
Continuing from my first post.....
The f22 has already undergone test flights, in which it proved that it can fly and I need to learn how to . The only challenge was to get the COG right and finding the right propeller. I had a few Hubsan props around and found only a couple of them generating enough thrust. All control surfaces work great and it can roll&climb pretty quick. Awesome model, except that I keep crashing it. This build was based on this :
Ultra Micro F22 Raptor Scratch build. (1 min 18 sec)
The spitfire is yet to take its maiden flight. Hoping that the rudder control is easier than the F22's Aileron/Elevator controls to learn on.BTW I have never flown an RC plane before - just the micro quads.
Will post a video, soon...
Old Sep 14, 2014, 10:02 AM
limmacslim's Avatar
Joined Jun 2012
Cool planes rajeshsl!
I especially like the look of the micro spitfire .
Old Sep 14, 2014, 05:01 PM
Germany, NRW, DU
Joined Feb 2014
Monocoupe V911 Peanut Size
Hi,
I was inspired to start micro modelling by a friend of mine who
showed me a lot (thank you Tobi) including his Microinvent Tramp.
I decided to make a build of Gordon Johnson's Monocoupe from 3mm Depron including the printing tissue technique to have a Micro Model.
I used a brushed 7mm Motor and a spare WLToys Heli V911 brick to keep the costs low.
31g weight over all including battery.
The first flight was very exciting and I was so happy that it was a full success.
Thanks a lot to Gordon that he shared 9 years ago his excellent pdf files
Monocoupe Spw 40 cm 31g Abflugbereit (2 min 4 sec)
Depronator71
Depronator71 is offline Find More Posts by Depronator71
Old Sep 21, 2014, 04:12 PM
Joined May 2014
Hi,
I have a couple of spare v911s lying around and want to build a very basic plane model from it. Given i am completely new to fixed wing and have never built a plane before i find all the info in this thread a little overwhelming. Can anyone guide me on what equipment i need to buy in addition to the v911 to get started and point me to some plans that would be suitable with the v911 electronics. I already have a devo 7e tx modded to fly v911 and some spare toy qaud props.
helibg is online now Find More Posts by helibg
Old Sep 23, 2014, 07:17 AM
Joined Nov 2012
foam, cf, uhu por, 0,5mm wire.... gearbox and 5/4 or 5/3 props
sharp knife, scotch tape
Wanted WTB: micro 1 cell brushless power system for um parkzone plane (ar6400 brick) ddrummer508 Aircraft - Electric - Power Systems (FS/W) 1 May 16, 2012 10:55 PM
Sold Moving sale! Clearing out some cool RC stuff! Cars, planes, helis- local pickup in OR aaronredbaron Non R/C Items (FS/W) 7 May 16, 2012 07:50 AM
Question Heli motor in a plane? metalfred Power Systems 3 Apr 18, 2012 08:44 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 06:16 PM
For Sale planes planes planes cheap milfiebre Aircraft - Electric - Airplanes (FS/W) 12 Dec 04, 2011 09:23 AM
